Drywall Install - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Bmarms
Old 04-21-2019, 07:00 AM   #1
Drywall install
I’m installing drywall in my basement. I cannot fit a 4x8 sheet down my basement steps. Is it best to just cut the sheets in half and install as 4x4 sheets? I’m going to hire a professional to finish it once installed.
Bmarms is offline   Reply With Quote
Old 04-21-2019, 07:26 AM   #2
Property Mgt/Maint
Rewards Points: 6,172
Re: Drywall install
I am more concerned about how you are going to prevent mold. I have cleaned up more than one moldy mess from attempted basement conversions. Does your basement stay dry?
[political signature removed]
Yodaman is offline   Reply With Quote
Old 04-21-2019, 07:27 AM   #3
Rewards Points: 2,040
Re: Drywall install
You don't have much of a choice if there is no other way. either 4x4 or 2x8 whatever works to get it in basement. before you cut it, I would ask the pro first who is doing the job for best advice on how you should cut it.
How is it studded/framed out? 18 inch, 24 inch on center?
jmon is online now   Reply With Quote
Old 04-21-2019, 07:33 AM   #4
retired painter
Rewards Points: 864
Re: Drywall install
Expect to pay more for the finishing as there will be more joints, mostly butt joints which take a little more work.
I agree with discussing this with your finisher first, he might even know a few tricks that may make hanging/finishing your basement easier/cheaper.
mark sr is offline   Reply With Quote
Old 04-21-2019, 07:35 AM   #5
Rewards Points: 5,280
Re: Drywall install
Definitely talk to the pro finisher first as they may have a preference or a few tricks. Example, maybe a 4' x 80" piece would fit and still hit the studs. A little waste but drywall is cheap.
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
Old 04-21-2019, 08:53 AM   #6
It’s dry.
Old 04-21-2019, 08:53 AM   #7
It’s dry
Yodaman likes this.
Old 04-21-2019, 08:55 AM   #8
Great idea. 24oc
Old 04-21-2019, 09:00 AM   #9
Bud
Great idea. Studs are 24 oc so perhaps 4x6 would be better than 4x4 and I can fit that size down my steps.
Old 04-21-2019, 09:05 AM   #10
Re: Drywall install
Another different approach might be 4x6 vertical topped with a 2x8 section.
Bud
Old 04-21-2019, 04:25 PM   #11
Property Mgt/Maint
Re: Drywall install
I think I would cut them at 24" x 8',
Run horizontal, starting at the top with a cut edge at the ceiling corner. Next pc goes in taper-to-taper which is very easy to tape and mud. Next you have cut edge to cut edge. The most difficult to finish, but at least it will be a comfortable 4' work height. Last pc again another taper to taper.
At 24 OC wall studs I would also use butt boards and staggered joints.
JMHO
Install bathtub after drywall? Laneman Plumbing 4 12-21-2018 07:09 PM
How would you install drywall to ceiling??? oodssoo Drywall & Plaster 8 12-01-2012 03:50 PM
Cement board over drywall during vinyl shower pan install asc12 Tiling, ceramics, marble 6 02-25-2012 07:19 AM
install ceiling box for fan while drywall is off collegetry Electrical 30 02-12-2012 09:17 AM
Can I install mesh back mosaic tile directly to primed drywall jenrao9991 Tiling, ceramics, marble 5 03-17-2009 06:08 PM
