Corner Bead Tile On One Wall, Drywall On The Other - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By XSleeper
Old 06-21-2020, 10:31 AM   #1
Rewards Points: 366
Corner bead tile on one wall, drywall on the other
At this corner, I will have tile the entire wall on the tubside with modified thinset, and half tile / half drywall on the other side. How do I install the cornerbead? Do I use mud on the backer board?
Corner bead tile on one wall, drywall on the other-e4ab130c-a16b-484e-8b65-5965d92d5ff8.jpg
dgfit is offline   Reply With Quote
Old 06-21-2020, 10:37 AM   #2
Rewards Points: 1,759
Re: Corner bead tile on one wall, drywall on the other
I would probably use a vinyl bead, set in durabond.
mark sr likes this.
XSleeper is online now   Reply With Quote
Old 06-21-2020, 10:46 AM   #3
Rewards Points: 366
Thanks - you would use durabond on all surfaces?
Old 06-21-2020, 11:01 AM   #4
Yes, bed the corner bead in it, and finish the tile side only with it. (Use regular joint compound on the other side) Keep in mind that you cant sand durabond so apply it neat and smooth. Durabond is water resistant. You just need to to be smooth enough for your tile. Be sure you check the corner bead with a straight edge when you mud it on. (A 78" or 96" level works well)
