Ceiling Discoloration - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By mark sr
  • 1 Post By Nealtw
  • 1 Post By DoomsDave
  • 2 Post By Theswed82
Old 01-09-2020, 05:30 PM   #1
DoomsDave's Avatar
Rewards Points: 8,352
Ceiling discoloration
Last winter I had some water intrusion and it stained part of the ceiling as shown. It’s covered with this funky popcorn stuff on it.
My question is: can I just scrape off the popcorn, seal and prime and paint; or would it be better to take out the ceiling and put in new drywall?
Also I’m planning on replacing those light fixtures with one ceiling fan in between them.
Thanks to y’all for your thoughts.
Ceiling discoloration-9e4dfdf9-9fd0-479a-8d56-22b1ed8012b4_1578608754628.jpg   Ceiling discoloration-2d774dc0-41d7-405c-a294-3386ae6992d0_1578608904443.jpg
Suffer not a fool, look not in the mirror.
Life is one long teaching moment.
DoomsDave is online now   Reply With Quote
Old 01-09-2020, 05:37 PM   #2
retired painter
Rewards Points: 1,362
Re: Ceiling discoloration
An oil base primer [use pigmented shellac if really bad] will seal the stain so you can successfully paint over it. Whether or not to replace the drywall is dependent on how solid the drywall is and if you suspect any mold on the reverse side. If you want to put in a ceiling fan you'd probably need to remove drywall in order to install a fan box.
DoomsDave likes this.
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
DoomsDave (01-10-2020)
Old 01-09-2020, 05:50 PM   #3
DoomsDave's Avatar
Thanks for your prompt response!
I’m pretty sure it isn’t drywall but that funky old fashioned plaster stucco stuff with wire netting in it. It’s cold to the touch unlike drywall that’s closer to room temperature. It appears to be in reasonably good condition.
Other parts of the house had much worse damage requiring removal of the ceiling including a “lower living room” about 20 by 25 feet. That funky stucco was masochism to remove and dispose of. I’d like to avoid having to more of that than necessary.
Old 01-09-2020, 05:56 PM   #4
retired framer
Rewards Points: 4,340
Insulation? mold? attic access?
mark sr likes this.
Do not use flat bottom gables with scissor trusses.
Old 01-10-2020, 03:36 PM   #5
DoomsDave's Avatar
This house has a funky attic that's much too small to get around in easily.
I know there's insulation. As for mold, not sure.
Old 01-10-2020, 03:42 PM   #6
retired framer
You will want to change the box to support the fan, then you will be able to inspect at least a hand full of insulation, I guess. So I would do that before painting, you can still use the light after that if you want.
Old 01-10-2020, 04:03 PM   #7
DoomsDave's Avatar
And, if need be, install more?
Old 01-10-2020, 04:09 PM   #8
retired framer
If you can.
Old 01-11-2020, 10:22 PM   #9
DoomsDave's Avatar
Hmm.
How about some 'dozer therapy?
Nealtw likes this.
Old 01-14-2020, 10:14 AM   #10
Sir Diddely Squat
Theswed82's Avatar
Rewards Points: 178
If was me I would be tempted just replace it all with new sheetrock. Open it up to attic to double check insulation. If need be add some more insulation. New electric boxes as well. That is a expensive option.
The other less costly option has been mention. Scrape and a good primer then paint.
Nealtw and DoomsDave like this.
Theswed82 is offline   Reply With Quote
The Following User Says Thank You to Theswed82 For This Useful Post:
DoomsDave (01-14-2020)
