A Bit Of A Nightmare With Mesh Vs. Paper In Corners - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 2 Post By Nealtw
  • 1 Post By jlhaslip
  • 1 Post By mikegp
Old 10-12-2017, 12:54 PM   #1
Rewards Points: 8
Unhappy
A bit of a nightmare with mesh vs. paper in corners
I hired a "contractor" to do some work and he bailed out on the project. So, I hired a guy to come and finish the work and this included some repairs made to drywall installation with corner tape instead of mesh left from the previous guy. New guy applied mud (ceiling float) over the mesh instead and now I am having some issues with how to approach this.
So, my question is, would it be possible to spray down this area with water to get the Sheetrock moist, then remove the mesh, so I can apply corners tape to the area where the new drywall was installed? I should also say that this is for the ceiling mainly, and where it butts against the walls.
I thought about pulling it all out but at this point I think it's going to cause a mess for the float and I could be dragged into refloating this area. This could also cause the corner bead we installed to come out and have to be replaced as well.
Just looking for the best way to approach this by keeping the corners 90*, not having it fall out over time, and not having this area of the house looking bumpy as it will be exposed to light most the time.
Thanks.
noplacelikehome is offline   Reply With Quote
Old 10-12-2017, 12:59 PM   #2
retired framer
Rewards Points: 12,784
Re: A bit of a nightmare with mesh vs. paper in corners
Forget about 90* corner and finish filling, and taper it out.
Mike Milam and chandler48 like this.
Old 10-12-2017, 04:55 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Drywall corners are almost never 90 degrees.
Fill and taper will work.
mark sr likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 10-13-2017, 05:11 AM   #4
retired painter
Rewards Points: 1,312
Paper tape is always preferred for inside corners. I had to use the mesh tape once on a corner repair - hope I never have to again! As stated above it's rare for any corner in a house to be a perfect 90 and as long as they look nice, it's not like anyone is going to measure the corner to make sure it's perfectly square.
mark sr is offline   Reply With Quote
Old 10-13-2017, 07:12 AM   #5
Rewards Points: 1,602
The only time you'll care about the not perfect 90 is when doing baseboard, crown molding, chair rail, etc. Otherwise it doesn't really matter. Even in those situations it's not a huge deal.
mark sr likes this.
mikegp is offline   Reply With Quote
Tags
corner tape , drywall , drywall ceiling , mesh tape
Rounded dry wall corners Smokey2706 Drywall & Plaster 2 04-13-2015 12:10 PM
Peeled off Sheetrock Paper - HELP!! HomeHell Painting 8 02-21-2012 05:14 PM
Taping drywall joints - fiber glass mesh or paper? RickT Painting 25 04-20-2011 09:09 PM
Repairing stucco felt paper titan7 Building & Construction 5 02-26-2011 08:44 PM
cement board corners ponch37300 Kitchen & Bath Remodeling 3 01-25-2009 05:50 PM
