Any Readymade Boxes Available For This? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By Nealtw
  • 1 Post By Mystriss
  • 1 Post By alok_sathaye
Old 06-06-2020, 12:23 AM   #1
Rewards Points: 50
Any readymade boxes available for this?
A few years back we came across a wall that had lights built into the wall creating a nice look. Ever since I have wanted to do something similar. Was wondering if there are any readymade boxes like these or would have to be created using 1x2 and 1/4" plywood?
alok_sathaye is offline   Reply With Quote
Old 06-06-2020, 12:26 AM   #2
retired framer
Rewards Points: 15,542
Re: Any readymade boxes available for this?
Is that an exterior house wall or something else.
Do not use flat bottom gables with scissor trusses.
https://www.fema.gov/media-library-d...6/chapter7.pdf
figure 7-14
Old 06-06-2020, 12:31 AM   #3
Rewards Points: 50
It's an interior wall with lights built into it.
Old 06-06-2020, 12:57 AM   #4
retired framer
It is likely a 2x6 wall to make room for the light box
the niche is usually short 2x4s with a full 1/4" plywood back and cut out plywood face. All made to fit in 5 1/2"
Mystriss likes this.
figure 7-14
The Following User Says Thank You to Nealtw For This Useful Post:
alok_sathaye (06-06-2020)
Old 06-06-2020, 04:02 AM   #5
Mystriss's Avatar
Rewards Points: 7,350
Might check out these in wall niches as a possibly easier alternative than trying to drywall or plaster it in https://www.bing.com/shop?q=inwall+nitche&FORM=SHOPTB
Nealtw likes this.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
The Following User Says Thank You to Mystriss For This Useful Post:
Old 06-06-2020, 02:43 PM   #6
Rewards Points: 50
I looked at them but most are the bathroom niches and bigger in size. Typically for a LED candle I don't need them to be more than 8-9" height with atmost a couple of inches depth. Since the candles themselves will be battery operated (rechargeable) and not much heavy I was looking to combine my idea with what @Nealtw suggests but use less heavier material. Might use a L-bracket to fix the niche to the drywall.
Nealtw likes this.
Old 06-06-2020, 05:34 PM   #7
Rewards Points: 822
Make your own design of the shape & size made out of
modeling clay.
Than use the clay model to make a plaster piece of the design by making a rubber mold than pour moulding plaster into mold can also use Hydrocal PLASTER THIS ONE IS VERY STRONG.
Also look @ Plaster Ornaments.
www.decoratorsupply.com
ClarenceBauer is offline   Reply With Quote
Old 06-06-2020, 11:10 PM   #8
In a little over my head
Rewards Points: 904
Have you searched for "soap niche"?
ratherbefishing is offline   Reply With Quote
Old 06-07-2020, 07:16 AM   #9
Rewards Points: 822
Another idea?
Call Lauren 803-403-5252 She may have one on hand if not send her a picture & she will make you one or as many as required.
