Is insulated siding right for my climate? - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Blogs > Windows on Wash
Rate this Entry
Posted 07-11-2019 at 06:07 PM by Windows on Wash
https://www.windowsonwashington.net/blog-full/is-insulated-vinyl-siding-necessary-for-homes-in-maryland?utm_source=hs_email&utm_medium=email&utm_ content=74575992&_hsenc=p2ANqtz-9mMa4iwyyrngeTmJ5u61Vve14NRBTHHfIkr84vh6hy-Ri8ztsnF02mnDqub4n969JR7cz6gyEEGCdhLHZ_juQmk-ek-CR55Eg7hxRxkFmOZzJHk3o&_hsmi=74575992
As the weather begins to get warmer (hello, summer!), you are probably thinking about all the ways you can keep your home cool and comfortable, while also ensuring you do not send your energy bills through the roof. There is nothing worse than opening your utility bill to find you have used way more energy than you anticipated! So, how do you ensure your home is doing its best to keep the warm air out and trap the cool air in? By ensuring your home is functioning at its optimal. There are a few ways to do this, but one of the most effective ways is by making sure your siding is working at its peak. If it is time to replace the siding of your home, there is no better time than right now before the summer heat really settles in.
However, choosing the right siding for your home is not always a simple task as there are a few things to consider such as price, durability, aesthetics and energy efficiency. The siding you choose also depends on where you live. If you live in the Maryland region, you also need to consider what type of siding can help reduce your heating and cooling costs year round. The good news is there are plenty of siding options available. However, it can be quite overwhelming when trying to make a decision. In this article, we will be discussing your siding options, and in particular, whether insulated vinyl siding is necessary when you live in Maryland.
The difference between insulated vinyl siding and regular vinyl siding
Insulated vinyl siding is regular vinyl siding with a layer of expanded polystyrene (EPS) foam insulation stuck to it. In comparison to normal vinyl siding, insulated vinyl siding significantly increases the R-value of your home, which essentially means a big reduction in your utility bills over the course of a year. Insulated vinyl siding comes in a variety of colors and often requires less maintenance than regular vinyl siding. It also offers better weather performance and more efficient sound control than standard vinyl siding.
What are the advantages of insulated vinyl siding?
There are plenty of advantages that come with choosing insulated vinyl siding over traditional vinyl siding, especially for homeowners in Maryland who want to save on their energy bills this coming summer (and year round). Here are some of the greatest advantages of insulated vinyl siding:
  • Efficient and affordable
  • No need to be painted
  • Minimal maintenance
  • Cannot be ruined by insects or water
  • Comes in a range of colors and styles
  • Excellent noise reduction
  • Highly durable and can withstand sudden temperature changes and extreme weather conditions
  • Eco-friendly
  • Lowers energy bills
  • Comes with a lifetime warranty
Insulated vinyl siding is durable and great value for money
One of the greatest appeals of insulated vinyl siding is its durability and insulation value. The foam backed vinyl material is designed to stop air escaping from inside your home by trapping the conditioned air inside, where it is supposed to be. It also allows your air-conditioning unit to work like it is supposed to, without making it work overtime. When an air-conditioning unit has to work overtime, your energy bills spike, and the lifespan of the unit decreases.
Do Maryland homeowners need insulated vinyl siding?
If you live in Maryland is insulated vinyl siding really necessary? Maryland sits near the Atlantic Coast, which makes it susceptible to severe weather patterns. That is why insulated vinyl siding is the best choice for Maryland homeowners because it can easily withstand sudden temperature changes and extreme weather conditions. Insulated vinyl siding is one of the best siding options to protect your home from heavy winds and rains that often frequent the Maryland region. And, because insulated vinyl siding is highly durable and wind-resistant, it provides your home with a sturdy weather-proof barrier that protects it from all the natural elements.
Posted in Uncategorized
Views 334 Comments 0 Email Blog Entry
« Prev     Main     Next »
Total Comments 0
Comments
