Slip Sticks To Measure From Here To There - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > How To Guides
Old 04-29-2015, 02:41 PM   #1
Rewards Points: 3,656
Slip Sticks to measure from here to there
To measure from here to there, especially doing inside measurements, these slip sticks are handy and accurate when used to set your saw stops. Leave the tape measure for those other non critical jobs.
If there will be several measurements within the range of your chosen sticks, put 3/4 masking tape on the stick surfaces and mark across the sticks with a pencil. Number each different measurement so it can be referred to and accurately changed at the saw.
Old 04-29-2015, 03:41 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 4,132
I thought you were talking about a slide rule, we use to call them slip sticks. LOL
New members: Please consider adding your location to your profile.
If you aim at nothing, you will hit it every time!
Jim
BigJim is offline   Reply With Quote
Tips on soldering slip joint on vertical pipe? darsunt Plumbing 2 04-06-2012 03:26 PM
Help with DIY Slip n Slide Project ffrllc General DIY Discussions 9 08-05-2011 06:47 PM
PVC Slip coupler msaeger Plumbing 5 03-13-2011 09:46 PM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 07:36 PM
