Seat A Tubeless Tire On A Dolley Or Lawnmower, Ect... - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 11-01-2013, 03:35 PM   #1
Dorf dude...
shumakerscott's Avatar
Rewards Points: 1,190
Seat a Tubeless Tire on a Dolley or lawnmower, ect...
New Dolley's ect are tubeless. Getting the tires to set on the rim is a pain. Not any more. This is so simple. Just take a strap or piece of cord, doesn't matter. Put it around the center and tighten. The bead will push out and then you can fill with air. So simple. I hope this helps you. dorf dude...
Seat a Tubeless Tire on a Dolley or lawnmower, ect...-pb010260.jpg   Seat a Tubeless Tire on a Dolley or lawnmower, ect...-pb010261.jpg
Today is only yesterdays tomorrow, Now get to work!
shumakerscott is offline   Reply With Quote
Old 11-01-2013, 03:42 PM   #2
Rewards Points: 13,450
I use a small ratchet strap so I can work with one hand.
In a jam I've even used my belt for small tires.
Still not seating, pick it up and bounce the tread part on the ground a few times.
shumakerscott (11-01-2013)
Old 11-01-2013, 04:36 PM   #3
Don't forget a match and some ether
poorboy01 is offline   Reply With Quote
Old 11-02-2013, 12:02 PM   #4
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
Sometimes when I worked at the tire shop, even that stuff wouldn't work. I'd just get pissed and throw a tube in there.
Mort is online now   Reply With Quote
Old 11-03-2013, 08:54 AM   #5
Bill Kearney
Rewards Points: 1,174
Yeah, that sometimes works. But if not at least there's the thrill of the WHOOMP! sound it makes, and the smell of your burnt off eyebrows or arm hair.
Me, I've just used my belt most of the time. But the strap with a lug wrench handle to twist it is a better idea, thanks for posting the picture.
wkearney99 is offline   Reply With Quote
Removing part of a concrete garage tire stop? Lurch96 Concrete, Stone & Masonry 5 01-04-2013 08:59 PM
Shower valve seat insert Markthenovice Plumbing 0 12-23-2012 08:58 AM
Window seat between two built-ins under low window questions. noone Carpentry 27 02-16-2012 07:41 PM
bathtub leaking... seat housing cracked? olnoln Plumbing 12 05-21-2010 01:46 PM
