-   How To Guides (http://www.diychatroom.com/f98/)
-   -   The Hows and Whys of Furring Strips. Part-1 (http://www.diychatroom.com/f98/hows-whys-furring-strips-part-1-a-44090/)
Willie T 05-08-2009 02:10 PM
4 Attachment(s)
One of the least understood, and therefore most often incorrectly installed items is the furring strip. If you do not understand why and how it is used, it usually goes on the wall wrong. In this article I will give easy-to-follow instructions on placing furring strips on a concrete block wall.
In this example, we will be using ” x 8’ long drywall screwed to 1-1/2” x 3/4” furring strips. Twelve feet is the professional length, but most homeowners use 8’.
No matter where you run furring strips, there will need to be extra perpendicular strips (usually 1 x 4’s) paralleling the floor, held up off the floor about ”. This is to nail the baseboard to later. If you are planning on installing crown molding, you will want to also run one of these along the wall a couple of inches down from the ceiling.
A point that will be addressed by KCTermite a few posts below this is to also not forget to run a "fire blocker" furring strip horizontally at the very top - whether you are doing crown molding or not. This strip needs to be held tightly up against the joists or trusses. And it needs to run all the way tight against the adjoining walls at either end, with no gaps between butted pieces. This is an important CODE requirement, so don't forget it. The only time this would not be needed is if, perhaps, you had a full concrete ceiling. Not usually too likely. (Trust me, most drywallers do NOT run the ceiling lofts tight enough to the walls to fulfill the requirements of this code issue.)
When you place the furring strips on the walls, cut them short enough that you will have a gap of about 1” to 1-1/2" at the top and at the bottom. In other words, do not butt your furring strips up against the 1 x 4’s. The electricians and TV guys like to run their wires through those spaces. Don't leave too much of a gap here, though. Some jurisdictions may require that you come back and fill these gaps with Fireproof Foam after the wires have been run. This is rare, but keep it in mind.
Part I. Beginning at a block corner
The first thing to think about is the fact that your sheet of drywall does not run all the way back into the corner. The reason for this is that the other sheet of drywall, the one turning the corner, sits off the wall an inch and a quarter because of how it is also mounted to the block. All ” drywall sits an inch and a quarter off the block to the face of the drywall. So don’t expect to start your sheet butted up against the adjacent block wall. It will be sitting an inch and a quarter off that wall.
But why even begin at a block corner? Simple. The perimeter of a house is done first so that you can butt your cut ends up against perpendicular walls. This hides those ragged cuts when the board is applied to the intersecting stud walls. And it is a lot easier to just drag a sheet right into the corner as you enter a room.
Let’s start. We’re using an eight foot board, so simply measure 8’-1/2” out from the corner of the block and make a pencil mark on the wall. Yes, if we were using a 12' sheet you would measure 12'-1/2".
Now draw a plumb line on that mark from floor to ceiling. Yes, use a level to do this.
Make an “X” to the side of that line farthest away from the corner.
Nail on a furring strip, right on top of the “X”, with the edge of the furring strip even with your pencil line.
What you just did was place the furring strip “nailer” for the very end of the eight foot board. The end of that eight footer will be placed right in the middle of that strip. This will give you 3/4" to screw the first sheet to, and 3/4" to screw the next sheet to. Now you want to place some more all across the area where the board will soon go so you can have something to screw the board to.
To do this, we will space furring strips every 16” all the way back to the corner. This is most easily accomplished by hooking your tape measure over the furring strip you just nailed on, and pulling it tightly back toward the corner.
Make a pencil mark at every 16 inches... 16... 32... 48... 64... 80... Don’t mark one in the corner yet. That starter strip in the corner is done a little differently than the rest.
Now draw a plumb line at each of those marks from floor to ceiling. Yes, use a level to do this too.
Make an “X” next to each of those lines on the side CLOSEST to the corner. No, this is not the same as the first “X” you made. And that’s OK.
Nail on a furring strip, right on top of the “X”, with the edge of the furring strip even with your pencil line. In this case the pencil line will be on the opposite side of the furring strip than it was on the first strip you nailed. Don’t worry about it. It’s supposed to be this way.
You are now ready to place the “starter” strip. This one is fun. It goes a full furring strip width (1-1/2”) away from the corner. That’s important. Here’s how I like to do this one:
Cut yourself a short length (about 6”) of furring strip. Hold this on the wall as a “spacer” to offset the “starter” strip. Place your furring strip against this “spacer”, and nail it in that spot with one nail. Move the “spacer” up and down as needed to place more nails, holding the furring strip tightly against your “spacer” each time.
Why did we hold that “starter” strip off the wall? When you go to screw on the board you will see. With the furring strip up tight in the corner, you would not be able to cleanly get screws into your second corner run (opposite corner). You’ll see.
All that is left to do now is to continue this layout on across your wall for the rest of the furring strips. Hook your tape on the end strip, and begin your 16... 32... 48... 64... 80... layout again, continuing on across the unmarked portion of your wall. This time, placing the “X” just past each mark you make. To check your work on these “running” strips, you should expect to see 14-1/2” between strips anywhere you check (except the “starter”)
Pull your tape from the center of any strip (except the "starter") and you will find 8' (or any multiple of 16) will fall right in the center of another strip. This keeps you from having to do a lot of unnecessary cutting.
Of course each time you come to a wall intersection, make sure you have an extra strip running alongside the wall stud (about 1/1/2” off the stud)
One final point to mention here could be very important to you. Wall joints tend to crack. Part of the reason for this has been determined to be the tight fastening of the board to that 'starter' strip. Some drywall installers do not fasten to that last furring strip at all. They prefer to leave it floating, allowing only the tape and mud to make the corner connection. This lets the corner flex and move with minute seasonal wall movements. You might find it beneficial to add one more furring strip centered between the starter strip and the beginning strip (#2) of your layout, and let that strip be the last one you nail to as you approach the corner, nailing your drywall. (But simply ending your nailing at #2 strip is just fine.) I do not show this on the drawing because some municipalities frown on this "floating" technique. (There's no accounting for officials who refuse to keep up with progressive innovations.)
BTW, the same 'floating' trick is used at the top of a wall where it meets the ceiling when trusses are used. All trusses tend to move up and down with the seasons. Letting the last section of ceiling board 'float' helps prevent cracking here too.
Go up to your TOOLBAR and click your ZOOM up to 200% (under the PAGE drop-down menu) if these pictures are too small to see.
DangerMouse 05-08-2009 02:29 PM
Originally Posted by Willie T (Post 271272)
One of the least understood, and therefore most often incorrectly installed items is the firing strip.
One of the least understood, and often misspelled words is firring. FIRING is what we did with our ceramic sculptures, crappy vases for grandma and ashtrays in high school.
-=chuckle=-
DM
Willie T 05-08-2009 02:56 PM
Originally Posted by DangerMouse (Post 271276)
One of the least understood, and often misspelled words is furring. FIRING is what we did with our ceramic sculptures, crappy vases for grandma and ashtrays in high school.
-=chuckle=-
DM
OK.... :( Corrected to reflect the current usage of the term. Yes, my spelling of firring was wrong, and I should be fired for that.
But a history lesson. "Firring" is a U.K. term for wood strips which are usually 50mm wide, tapered and fixed above wood roof joists to provide drainage falls below roof boarding. Originally, in the U.S., a piece of fir wood was used whenever padding out an area was necessary, and the term got itself adopted. Not too sure when or where that bastardization of furring came into common use. But you sure won't get too far nailing a hunk of fur on the wall. :no:
But, today, the kids all say furring, so that's what it is. :wink:
Willie T 05-08-2009 04:02 PM
Last edited by DangerMouse; Today at 03:32 PM. Reason: i misspelled furring...sheesh
Doncha just hate it when that happens? :thumbsup: Way to cop. That's righteous. A lesser man might not have stepped up.
DangerMouse 05-08-2009 04:24 PM
that's what i had to begin with.... firring.... then i googled it and it asked did you mean FURRING... evidentally either is acceptable, though since it's normally fir, well duh.... re-edited to correct... again... or back to correct..... or something...
DM
Willie T 05-08-2009 04:29 PM
DM
I admit I've been hearing it with a "u" for years. But this old guy just can't get used to it. I'm trying. :yes:
But there is just no excuse for me trying to burn up all those strips in a kiln. Just careless.
jordy3738 05-23-2009 09:56 PM
Nice post...I've been installing cabinetry for some time. When I first started, it took me a while to make the connection that the long screw that wouldn't sink all the way was hitting a block wall behind the strip.
Now when I have a kitchen to install that's one of the first things I look for, block or stud wall.
Termite 05-24-2009 12:10 AM
Good post WillieT. Another thing with furring strips that a lot of people forget is that they need to be fireblocked at the top if the space they create communicates with the floor system or attic above. A horizontal strip of the same thickness does the trick.
Willie T 05-24-2009 05:11 PM
Added to the text above. Thanks. :thumbsup:
DIYtestdummy 05-31-2009 09:32 PM
I've always seen it spelled "firring" until I got on the forum. Home Depot calls them 2x2's...
:laughing:
604Dave 12-28-2011 10:44 PM
....plastic furring strips, they are 3/8" and corrugated so they can run horizontal. I put up vertical cedar channel siding on my new house....which meant I needed to run something horizontal yet still let the air flow and if there is any moisture behind the siding it can still flow down and out. Just remember to always put big screen on the bottom and top.
Dorado 02-18-2013 07:52 AM
Just want to mention that they make steel furring channel, and "high hat" steel furring channel. The high hat is hard to get. I wanted to keep my walls fireproof even though the interior walls aren't required to be fireproof in my "fireproof" building. I'm building a soffit and I'll have to add a couple of drywall strips on the channel to get the spacing from the wall that I need. The larger drywall that will make the wall of the soffit will be screwed through the strips, into the channel so the strips only need a little compression strength. I was wondering how wide I'd have to make the drywall strips if I wanted to use them alone as furring. They should make a standard for that. Also, high hat channel is sometimes used for roofs and roofing supply places need to know. I guess there's almost no demand for it, but it's still a roofing product.
jburchill 03-01-2013 02:58 PM
11 Attachment(s)
Resurrections of an old thread, but what insulation do you use in between the furrings?
