Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 08-14-2009, 10:50 PM   #1
Learning by Doing
Leah Frances's Avatar
Default How To use a router to make crown moulding
Problem: my historic house has crown moulding that is unique - store bought moulding has wrong proportions and shallow spring angles.
Here's the three piece unit I need to recreate. The right side is the 'low run'.
1. I glued up some 2x2x36 poplar stock so it would be easier to run through the router.
2. I marked the stock with the original pattern:
3. Using my table saw I eased the waste corner of the stock so the router will have less work to do:
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-14-2009, 10:55 PM   #2
Learning by Doing
Default How to use a router to make crown moulding 2
4. Using the bit for the lowest cut I make the first pass:
5. Using the bit for the next cut I make the second pass
6. Using the table saw I make an angle cut and a straight cut to separate the moulding from the stock.
Here is the original with the recreation:
It's not a perfect match, but it's in the ballpark
Old 08-14-2009, 10:59 PM   #3
Learning by Doing
Default How to use a router to make crown moulding 3
For the top run I used some bigger stock to start:
1. Marked the pattern on the stock
2. Eased the corner with the table saw:
3. My first bit required more than one pass. I started with the bit in a low position and slowly increased it's height for successive passes:
Old 08-14-2009, 11:03 PM   #4
Learning by Doing
Default How to use a router to make crown moulding 4
4. I changed bits for the second pass - I had to slow down the router for the bigger bit:
5. Pass 3 also required changing the height of the bit some.
Here's the almost final product with the original:
It still needs some fine tuning - but this procedure yielded me a finished product in my test runs that I will be happy using. Next step is to go into mass production.
Old 08-15-2009, 02:09 AM   #5
Administrator
Send a message via AIM to Nathan
Great walk through... thanks for adding that!
Nathan
Have You Registered Yet?...
CLICK HERE!
Nathan is offline   Reply With Quote
Old 08-17-2009, 12:11 AM   #6
Building codes guy, Mod
thekctermite's Avatar
Glad it worked out for you Leah, I have to admit my previous skepticism! You did well.
Question...How are you going to cut the back of the crown from the patterned piece you show in the last picture. I'd be really concerned with the safety of doing it on the tablesaw. That would be a kickback waiting to happen.
Or with the overall projection of the three piece crown do you have enough room to basically leave it as it is and hang it?
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 08-18-2009, 02:16 PM   #7
Learning by Doing
Termite - allay your fears. I'll post the pics of cutting the moulding free. I assure you - it's Team Safety First at my house.
Old 08-18-2009, 07:48 PM   #8
Fixer-'til-broker
DIYtestdummy's Avatar
SWEET!
I've been thinking about doing the same for my base molding, since nowhere local has anything I want. Now that I am back on my feet (sprained foot), I have a new router plate that fits in my saw table and I've been planning jigs and sleds and bits...OH MY!
"Waitaminute, don't we have 2 rakes?"
http://www.youtube.com/watch?v=EJxpv...eature=related
DIYtestdummy is offline   Reply With Quote
Old 08-19-2009, 09:44 PM   #9
Learning by Doing
Default Cutting moulding from the stock -
Here are the next steps:
6. Using a slightly canted angle (I used 7 degrees) and set the desired depth, I make the first cut to separate the top of the moulding from the stock:
7. Using a 45 degree angle and setting a deeper depth I make a second cut for the 'back' of the moulding:
8. Using the same 7 degree angle I separate the moulding from the stock with the final cut:
Doing it in this order allowed me work both sides of the stock without ever making any risky cuts.
I ran 56 feet of one pattern today. I have a 'helper', an 11 yo who lives on my street. Tomorrow, her job is to do some light sanding and prime the moulding I made today!
Old 09-04-2009, 12:33 AM   #10
I’ll be sure to keep everyone posted.
Thank you very much for the lesson. I knew that I can do this in better way.
document internet management software property asset project find the right internet management software for you document internet management software property asset project
hightlow is offline   Reply With Quote
More On This Topic
Hi! This is Bobby Hester on behalf of expertvillage.com. In this clip, we are going to demonstrate how to cut base moulding on an outside corner. By outside corner, I mean that you have a wall right here and this is the outside corner that you are going... Read More »
Hi! This is Ed Reyes with Master Builders from Tampa, Florida. On behalf of Expert Village, this is how you use and maintain a miter saw. So basically the complete use of this machine involves your sliders, your back slider which slides back and forth... Read More »
Make a Bevel Cut with a Saw
Make a Bevel Cut with a Saw by Expert Village
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to make a bevel cut. First I am going to make sure there are no nails or foreign objects in my stock that I will be cutting. Next I will be checking my saw to make... Read More »
Circular Saw Angle Cuts
Circular Saw Angle Cuts by Expert Village
In this we're going to talk a little bit about some of the angles that you're going to be cutting with your, with your circular saw. Again, when we're making adjustments we're unplugged. We just did a forty-five degree cut didn't we so now if you look... Read More »
In this clip, we're going to cut a twenty-two and a half degree angle. I'll show you why in a minute. So, first making sure our saw is unplugged, we're going to, we're going to release the angle fence. You see the twenty-two and a half degree mark, and... Read More »
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 11:05 PM
Crown Moulding throughout forcheck Carpentry 16 11-21-2007 11:20 PM
Is it best to caulk new moulding edges before painting? Davo Painting 8 04-15-2007 01:12 AM
Crown Caulking Not Sure Carpentry 3 08-18-2006 11:40 PM
Crown moulding complete forcheck Carpentry 0 12-25-2005 11:18 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
