How To Spray Orange Peel Texture In A Can On A Drywall Repair - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 10-12-2014, 04:12 PM   #1
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 896
How to spray orange peel texture in a can on a drywall repair
In this short video clip I'm demonstrating how to spray a can of Homax's oil base orange peel texture on an actual drywall repair.
**Be sure to shake the can well before trying to spray the orange peel texture!
I'm spraying the orange peel texture on an kitchen remodeling project.
The area that needs the orange peel sprayed to is on a soffit between the kitchen and dining room that has a heavy orange peel that I need to match. The drywall repair was where a the homeowner had tried to do a DIY drywall repair and failed!
So once the tape joint and corner bead were repaired in that area it was time to prep the area to spray the orange peel texture.
All i can say is cover everything that you don't want texture to get on in the surrounding area around the repair.
☆Materials needed to prep and spray the orange peel texture☆
1) Aerosol can of Homax Orange peel texture (I prefer the oil base)
2) Masking paper- 12″ to 16″
3) 3M paper machine (optional)
4) Masking tape 1.5″ and 3/4″ for paper machine
5) .31 mil light plastic (optional)
6) 5 in 1 tool or putty knife
7) Drop cloths
8) Safety glasses
9) Respirator (breathing protection)
Read more details on how to apply an orange peel texture here: http://peckdrywallandpainting.com/ho...ture-in-a-can/
Sir MixAlot is online now   Reply With Quote
The Following 3 Users Say Thank You to Sir MixAlot For This Useful Post:
Jmayspaint (10-12-2014), kwikfishron (10-13-2014), r0ckstarr (11-21-2014)
Tags
aerosol can , how to , orange peel , spray , texture
Really thin drywall repair yupper Drywall & Plaster 4 07-22-2014 08:02 PM
Drywall repair REXAMUS Drywall & Plaster 7 12-21-2011 03:24 AM
Same Ceiling: orange peel and knockdown sir_rob Painting 17 10-01-2007 04:28 PM
several problems while texture painting ceilings and walls carrotguy Painting 2 05-25-2007 03:38 PM
What to use to spray texture on new drywall? klemmy Remodeling 16 03-28-2007 06:14 PM
