Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 11-03-2009, 07:35 PM   #61
New home owner!
Red Squirrel's Avatar
That was a useful tutorial. I've never done it before, but been thinking of trying, and water pipes scare me more then anything else as far as DIY so I want to make sure I do it the right way!
Old 11-03-2009, 07:49 PM   #62
Custom Cabinet Maker
Squirrel: CLEAN CLEAN CLEAN CLEAN AD INFINITUM !!!!!
once all parts are cleaned DO NOT TOUCH THE AREA with your hands, apply flux to ALL parts,make sure all pipes are bottomed into the fittings, heat AWAY from the joint and draw the solder into the joint, it will suck right into and run thru by itself and you will see it start to drip out, keep a rag with you and once soldered gently WIPE the joint. See it is that EZ. After a few hundred times it becomes second nature
skymaster is offline   Reply With Quote
Old 11-03-2009, 09:47 PM   #63
New home owner!
Yeah I'm sure it becomes easy and less "scary". I used to feel a bit the same way about electrical and now I'm doing it like 2nd nature. The other day was totally random. "it's kinda dark in this room" a minute latter I'm running a new socket from the existing light and have more light within half an hour.
What scares me with water pipes is the possible pending disaster if I screw up, but don't screw up bad enough for immediate issues. I have servers in my basement. Guess I'm just paranoid.
Old 11-04-2009, 02:11 AM   #64
Building codes guy, Mod
thekctermite's Avatar
Originally Posted by gbwillner View Post
Why not? The heat guns heat up to 1000 degrees, and from what I understand, the solder melts at 240 degrees. I saw a guy who said he does it without problems- but I really haven't seen too much info about it. I just bought a milwaukee heat gun (570/1000 degrees) hoping I could also use if for this purpose (in addition to others)- it even comes with an attachment for soldering pipe (hook nozzle).
Here it is-
http://www.milwaukeetool.com/Product...C%3a+Heat+Guns
Just wondering if anyone had tried this- otherwise will go with the torch.
Thanks.
Go with the torch. It is tried and true and inexpensive for a basic model that'll get the job done. Plus it is fun to melt things with fire. The idea is to get the fitting hot in a hurry, not to warm it up slowly. If too much time is taken...No matter how much heat you have...The flux will boil right out.
If heat guns worked for soldering copper pipes you'd see professional plumbers using them (and you don't). It would certainly be cheaper than a professional turbotorch and the associated gases and bottles that they have to pay to refill.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 11-04-2009, 09:33 AM   #65
Extreme DIY Homeowner
Scuba_Dave's Avatar
Can you refill the small propane & Mapp bottles?
Or are they just disposable ?
DIY Chatroom Moderator
Not a Pro or for hire, I have enough to do on my own house, Just Look !!
http://www.diychatroom.com/f49/house-renovation-ongoing-37438/
Old 11-04-2009, 10:14 AM   #66
The ones sold around here are not refillable. It should specify the parameters on the cannister.
Ron
More On This Topic
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
How to Fit Copper Pipes
How to Fit Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and back with you on copper piping. Here are he three pieces that we are going to put together. I've got the flux and we've got our torch ready to go, dry fitted them. We know that everything is fitted... Read More »
Hi. My name is Curtis Enlow. And on behalf of Expert Village I'm going to show you how to plan, setup and equip a work area for radio control models. In addition to all of the mechanical tools, you're going to need some electrical tools as well. You'll... Read More »
How to Sweat Copper Pipes
How to Sweat Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and we are working on our pipes. We have got pretty much everything ready to go. We have got our flux on. We have got our torch ready and our solder at hand and I am just going to fit these now and the flux... Read More »
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 12:24 PM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 10:53 PM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 09:20 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 10:59 AM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 10:18 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
