How To Solder Copper Pipes - How To Guides - Page 4 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 04-22-2009, 11:32 AM   #46
Originally Posted by J187 View Post
Not sure if it's been mentioned, but a good trick to knowing when you've heated enough for the solder is that the flame will start to give off a green hue...
That reminds of a camp fire trick that we used to do years ago!
We drilled many, many holes all around a piece of 1 1/2" copper water pipe!
When this is placed in a camp fire, it gives off emerald green flames!
Something to amuse the kids! (grin)
Old 05-07-2009, 01:48 PM   #47
Solderless repair on a coupling joint
I have tried soldering and found Rescue tape or the InstaClamp to work quick to repair leaks on solder joints on my copper pipes.
www.rescuetape.com or www.instaclamp.com
Sure saved me a lot of time and money and from paying a plumber extra after I screwed up the job. Oh yeah my wife likes the fact that she didn't have to go the whole weekend without hot water.
Enjoy!
SozoForce is offline   Reply With Quote
Old 08-05-2009, 07:01 PM   #48
I'm not an expert in soldering, but I did recently read some good articles on the subject. there's one on {link removed - please stop posting the same links to try to drive people to your site} basic techniques as well as an article on{link removed - please stop posting the same links to try to drive people to your site}. I'm just starting to learn my way around this stuff so I'm no help myself, but maybe these will help point you in the right direction.
louwatters is offline   Reply With Quote
Old 08-12-2009, 10:41 PM   #49
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Originally Posted by thekctermite View Post
Here's a very basic pictorial lesson on soldering copper pipe together. I'll hit on the high points...
Thanks for taking the time to post all this great info.
Sir MixAlot is offline   Reply With Quote
Old 08-13-2009, 11:43 AM   #50
Nice thread. I had a heck of a time (gave up) sweating some copper pipe a while ago. Prep was good, got new solder, flux, etc. It just wouldn't work for me. Years ago, the lead solder was easy as pie. I got a MAPP torch, and told myself I'd practice, but still haven't.
Is MAPP the key for the 'new' solder?
VelvetFoot is offline   Reply With Quote
Old 08-13-2009, 11:50 AM   #51
Registered User
Termite's Avatar
No, not at all. Propane is more commonly used. Mapp gas is hotter...Once you get the hang of it mapp gas is great but it certainly won't make or break you.
If you failed at soldering I'd look toward two things first off:
1) water or steam in the lines. Even if there is water downstream or upstream it will migrate to the heated joint and prevent you from succeeding. The bread dough trick works wonders to deal with this.
2) unclean fittings and pipes. Gotta use a wire brush on both.
Old 08-13-2009, 11:50 AM   #52
Registered User
Termite's Avatar
Glad some folks are getting some use out of my info and the subsequent tips from others!
Old 11-02-2009, 11:09 AM   #53
Rewards Points: 150
Any advise on the use of a heat gun instead of a torch to heat the solder?
THX
gbwillner is offline   Reply With Quote
Old 11-02-2009, 11:19 AM   #54
Rewards Points: 5,336
THX
The advice would be not to use it, because it won't work. Torchs are pretty cheap and have a low learning curve. If you're soldering 1/2" and 3/4", you can use a small propane or mapp gas unit. With larger pipe sizes it's problematic.
Ron
Old 11-02-2009, 11:20 AM   #55
This thread is old but I got notified so I thought I'd chime in once more.
I found the secret! I got a blister pack by Oatey that came with self-tinning flux and solder that said it was just as easy to use as the old stuff, and it was! I think the key was the self-tinning flux.
Old 11-02-2009, 01:04 PM   #56
I've always used a damp rag to wipe the solder right after finishing
I noticed on one pipe that there is green "residue" - must be left over flux
I've also pre-tinned (soldered) pipes before putting the fitting on
Once the pipe slips in I add a touch more solder & it's good
Old 11-02-2009, 02:48 PM   #57
Rewards Points: 150
Ron
Why not? The heat guns heat up to 1000 degrees, and from what I understand, the solder melts at 240 degrees. I saw a guy who said he does it without problems- but I really haven't seen too much info about it. I just bought a milwaukee heat gun (570/1000 degrees) hoping I could also use if for this purpose (in addition to others)- it even comes with an attachment for soldering pipe (hook nozzle).
Here it is-
http://www.milwaukeetool.com/Product...C%3a+Heat+Guns
Just wondering if anyone had tried this- otherwise will go with the torch.
Thanks.
Old 11-02-2009, 06:39 PM   #58
Here it is-
Thanks.
My heat gun has no such option. If yours did, you might have included that info in the post.
Try it on a scrap piece before the actual work.
Ron
Old 11-03-2009, 02:51 PM   #59
Custom Cabinet Maker
tho a heat gun may well be able to solder pipe I for One do NOT want to have to run an EXTENSION CORD a gazillion feet long and thru obstacles to get to a pipe :}:} I take my Mapp or Acetylene B tank. way way easier
skymaster is offline   Reply With Quote
Old 11-03-2009, 06:35 PM   #60
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 70
That was a useful tutorial. I've never done it before, but been thinking of trying, and water pipes scare me more then anything else as far as DIY so I want to make sure I do it the right way!
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 11:24 AM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 09:53 PM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 08:20 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 09:59 AM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 09:18 AM
