Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 03-15-2009, 07:14 PM   #31
Building codes guy, Mod
thekctermite's Avatar
Originally Posted by bjbatlanta View Post
Great "how to" KC! Wish I had learned the "bread trick" long before I did. It would have saved me much aggravation and "spouting of obscenities"! I noticed the yellow gas bottle in your picture of supplies. It might be worth mentioning that it is Mapp gas and burns hotter than regular propane.
Thank you sir! I mentioned the mapp gas in post #1 but didn't mention how it gets hotter than propane. I like the stuff.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 03-15-2009, 07:36 PM   #32
Drywall contractor
Sorry KC, I see that now. As usual, I was going for the "visuals" more than the "script". (Simple things for simple minds.) And hopefully we'll hear positive updates from "jpelzer". (Hope he's got the # for 911 "memorized" though....)
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-15-2009, 10:49 PM   #33
Experienced goon
I have a direct line. They're talking about fitting me with a GPS bracelet that sends my whereabouts whenever it detects that I'm on fire. That should speed things up. Not sure how to test that though.
jpelzer is offline   Reply With Quote
Old 03-16-2009, 12:36 PM   #34
Default sweating (soldering) a ball valve
WATCH OUT, most of the newer ball valves are plastic/nylon etc., it can't take any torch heat whatsoever.
pop the bonnet off and keep the ball and stem safe. Put a bit of lube on the ball when you reassemble the valve, as a smaller valve may lose shape if heated to long. With MAPP gas, the fixture heats up much quicker, which is better. so don't keep the flame on it longer than needed. when the joint is full, you will know as the solder will just drip off. If the solder beads up outside the joint, you've burnt of all the flux. sweating pipes is actually very easy. just need to keep a couple things in mind, and remember to wipe the joint well afterwards. do NOT try and cool it too quickly.
allencd@cox.net is offline   Reply With Quote
Old 03-31-2009, 12:21 PM   #35
Originally Posted by Wildie View Post
I have a question! The code in my area requires that we would use 'silver' solder, rather than 'lead'.
My question is, can I still use the 'Vaseline' paste that I have on hand, or does it require a special paste designed for silver?
Lead solder hasn't been sold in stores in many years. About the only place you'd pick it up is at garage sales and at your Dad's house.
The solder paste sold today is also lead free.
The ,"vaseline" reference will be confusing to the newbies. You don't use that in soldering.
Ron
Old 03-31-2009, 01:58 PM   #36
Ron
Thanks for the reply Ron!
The reason for my question was that I have a few containers of this 'flux' laying around and was thinking that I may as well toss 'em out! I have no lead solder to use it with!
I've never heard of someone referring to paste flux as 'vaselene' until I read it here in this thread!
Not only will it confuse the newbies, it confused me, as well!
Old 04-01-2009, 10:07 AM   #37
Joe F's Avatar
Great thread. Application and theory in one easy lesson!!!
I can do OK soldering 1/2, 3/4 and even 1", does anyone have any tips for success on the bigger stuff 1 1/4 and up?
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 04-01-2009, 10:44 PM   #38
Custom Cabinet Maker
a minimum #5 tip and acetylene :}:} works well
skymaster is offline   Reply With Quote
Old 04-02-2009, 12:04 AM   #39
Extreme DIY Homeowner
Scuba_Dave's Avatar
Originally Posted by 47_47 View Post
Wipe the joints with a wet rag after soldering to remove the excess flux. Remaining flux will continue to etch (eat) the copper pipe.
Sure, now ya tell me
Old 04-03-2009, 11:51 AM   #40
Well Dave, you never asked. Let me tell you there is another item you must wipe after you're done.
47_47 is offline   Reply With Quote
Old 04-08-2009, 12:18 AM   #41
Knucklez's Avatar
this is how i unwind the solder.. notice how the end has been circled? this helps me reach around the pipe when it is hot enough.
i hold onto the spool while soldering
Knucklez is offline   Reply With Quote
Old 04-08-2009, 12:23 AM   #42
Knucklez's Avatar
a question.. but first a story, so sit down and listen to
one time.. i realized my solder join sucked and i needed to touch it up cause it was leaking. so i opened a sink valve downstream used my air mattress pump to blow out the water. then i hit the pipe with some heat and tried to add more solder. unfortunately this did not work to stop the leak..
so i decided to remove the old 90 elbow and start over, maybe with a pre-soldered copper fitting (i like these!).
so i heat up the elbow and start hitting it lightly with a pair of plyers until the elbow pops off.. but it came of with a SPLASH OF HOT SOLDER that hit me in my eye.
and this is why i tell people i will never get contact lenses, my glasses have saved my eye sight more than once!
this leads me to my question..what are your safety tips with respect to soldering?
Knucklez
Old 04-13-2009, 10:18 PM   #43
Knucklez's Avatar
how to solder against gravity..
ok, i'm not a pro, so this is how i did it. but it is reliable, easy, and has never leaked (knocks on wood).
1) buy copper fitting that is "PRE-SOLDERED". it costs 50% more, so that 66cent copper elbow is 99cent. they sell at HD and no doubt everywhere else.
2) you still want to add flux because of the benefits. apply heat until you see the solder melt and it flows to the edge where you can see it.
3) wipe joint off when it cools down.
4) done
Knucklez
Old 04-20-2009, 02:16 PM   #44
They're all fixer-uppers
J187's Avatar
Not sure if it's been mentioned, but a good trick to knowing when you've heated enough for the solder is that the flame will start to give off a green hue...
TRY IT, IT'S SO MUCH FUN!
J187 is offline   Reply With Quote
Old 04-21-2009, 04:07 PM   #45
Res Ipsa Loquitur
One item I always try to remember and tell friends when working on home projects- especially plumbing- Don't work late night or Sunday eves- By experience only work on plumbing when the supply stores are open! I have had my occasions where I had to keep the water off until the store opened the next morning for replacement parts.
Did you ever stop to think, then forget to start again?
handyman78 is offline   Reply With Quote
More On This Topic
What is Copper Sweating?
What is Copper Sweating? by Expert Village
Hey everybody, Don Golden here for Expert Village and have I got a topic for you. Okay, this is all about copper. No, not stuff you want to wear, the jewelry on your hands or wrists. It's about copper piping. Why do you care about copper piping? It is... Read More »
Hey everybody Don Golden for Expert Village and we're back with copper piping and we've cleaned the inside and the outside of the pipe that we're going to be soldering today or sweating and if you're going to use this copper as a true water application... Read More »
Hey it's Don Golden again for Expert Village and we are going to talk about copper pipes today, how to work with them, how to cut them, how to sweat them and what I want to show you now is a very important aspect of getting these things together and... Read More »
How to Fit Copper Pipes
How to Fit Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and back with you on copper piping. Here are he three pieces that we are going to put together. I've got the flux and we've got our torch ready to go, dry fitted them. We know that everything is fitted... Read More »
Hey good people Don Golden here with Expert Village and we are working on our solder piping and guess what? Uh-oh, I made a mistake. Not really but you know what, we're not dead in the water here because this stuff heats up and comes apart again as... Read More »
Knocking Copper Hot Water Pipes in Winter desron1964 Plumbing 5 11-19-2009 12:24 PM
Replacing galvanized with copper pipes. Twinvtec Plumbing 18 02-24-2009 10:53 PM
Burying exposed copper pipes ryan_s HVAC 1 11-20-2008 09:20 PM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 10:59 AM
copper sink and standard drain pipes chefnmusic Plumbing 3 10-11-2008 10:18 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
