Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 02-19-2009, 11:58 PM   #1
Default How To Replace an Old Garage door Lock system
I inherited a very obsolete garage door locking system with my house.
There were cables attached to the lock, when I turned the handle a metal cord that wraps around a plate would pull two pins out from under two stops and allow the door to be opened.
The springs in the pins wore out and they wouldn't engage when I let go of the handle.. garage door stayed open.
I was unable to find any parts anywhere because the thing was so old
1) Removed old cable
2) Measured out space between center of handle and the middle of the pins
3) Got piece of metal stock 1x1/4
4) Lined up stock with existing holes in the pins marked holes on metal stock
5) Lined up stock with handle plate marked holes for both
6) Drilled holes in the metal stock
7) Drilled holes in handle plate.
8) Attached bolts into 4 holes Pin to stock, stock to handle plate, handle plate to stock and stock to pin
9) Door works like new
Cost:
1 free piece of metal -Craigslist ,
45 minutes of work
4 bolts and 4 nuts I had laying around
There are a few of these doors where I live I am sure they were pretty common in the 60's Hope this helps some one out.
Andrew [IMG]file:///C:/Documents%20and%20Settings/Administrator/My%20Documents/My%20Pictures/Garage%20door.JPG[/IMG]
apetrag is offline   Reply With Quote
Old 04-02-2009, 10:04 PM   #2
Very helpful info. Thanks.
simpo is offline   Reply With Quote
Old 09-03-2009, 03:15 AM   #3
Thanks for sharing
!!iamtheguy is offline   Reply With Quote
Old 09-03-2009, 11:09 AM   #4
Old School
Willie T's Avatar
But how did you get the locking spring action to work again when you simply let go of the handle?
Willie T
Old 09-03-2009, 07:31 PM   #5
Safe, Most of the Time!!
brokenknee's Avatar
Are you saying you replaced the cable with a metal flat stock? How did you keep the rod from falling down? I would assume there is no spring action to close/lock the door again?
Post a picture so we can see your finished work.
edit; not trying to nit pick, I am just not clear on how you did this.
"Clarity to Agreement" Dennis Prager
alot? a lot. unthaw? thaw.
brokenknee is offline   Reply With Quote
Old 09-07-2009, 09:31 AM   #6
Hey Guys,
The door doesn't spring back any more, its a manual turn to open and close.
There are two pins at either ends that stop the door from opening. They are part of the door, the cable used to be attached to both. I just swapped cable for metal stock. Working on the picture will post.
Old 09-07-2009, 04:20 PM   #7
Yeah! I am with you and wishing you for great time!
All the best!
Hershel8 is offline   Reply With Quote
More On This Topic
Hi I'm Drew Finn here for expertvillage.com we are going to show you how to install garage door opener today this is being filmed by Black Dog Video you could visit us at blackdogvideo.biz. Now we are going to attach to the traveler some people call it... Read More »
On behalf of expertvillage.com, I am Jim Koch and today we are talking about a locksmith would access to your house when you've locked your keys in or lost your keys. We are going to talk a little bit about security and some of the things you can do to... Read More »
Hi I'm Drew Finn here for expertvillage.com we are going to show you how to install garage door opener today this is being filmed by Black Dog Video you could visit us at blackdogvideo.biz. Now we are going to have to but the base of rail, mount it to... Read More »
Hi! This is Daniel on behalf of Expert Village. In this clip, we are going to be discussing the hole saw for drilling the main hole in the door for your deadbolt and we are also going to drill the main hole. When dealing with a hole saw, this happens to... Read More »
Hi, this is Jon and in this clip we will be removing our door. Now that we have cut all of our nails that is holding our door in place, the door is loose and we're ready to completely remove it. Now taking a look at the threshold on the bottom of the... Read More »
Detached garage setup - Switch loop setup jamiedolan Electrical 3 02-07-2009 02:08 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 06:57 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 09:31 AM
Size A/C system properly 70stang HVAC 1 03-26-2006 09:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 12:56 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
