How To Repair A Doorknob Hole In Drywall - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 12-13-2014, 08:05 AM   #1
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
How to repair a doorknob hole in drywall
In this video I'll be demonstrating how to repair a hole in drywall from a doorknob that went through the drywall on a wall because there was no door stop or it was pushed open to hard and the doorknob went through the drywall.
Because just applying joint compound isn't a good fix for this drywall issue if you want the repair to last!
I'll show you the step by step process from adding a furring strip to attaching the drywall, to a nice little trick on cutting the hole out and having a perfect drywall fit every time.
I'll also show you how to apply the fiberglass mesh tape and how to apply each coat joint compound to the drywall repair on your wall.
If you have any questions please feel free to ask.
Good luck on your drywall repair!
Sir MixAlot is online now   Reply With Quote
The Following 8 Users Say Thank You to Sir MixAlot For This Useful Post:
curtd (01-27-2015), Druidia (02-15-2015), gma2rjc (01-20-2015), Gymschu (12-13-2014), oh'mike (12-14-2014), r0ckstarr (12-14-2014), RHeat (01-15-2015), ZZZZZ (12-16-2014)
Old 12-15-2014, 11:37 PM   #2
Rewards Points: 2,218
Thanks. That was very helpful and you made it look easy.
I have a lot of old receptical holes to fill in my house.
Startingover is offline   Reply With Quote
The Following User Says Thank You to Startingover For This Useful Post:
Sir MixAlot (12-16-2014)
Old 12-16-2014, 06:59 AM   #3
Rewards Points: 918
That's great! Happy to help.
Let me know if you have any questions once you start your project.
Old 01-15-2015, 03:53 PM   #4
Rewards Points: 106
Thanks for the video. It looks easy enough to do
RHeat is offline   Reply With Quote
The Following User Says Thank You to RHeat For This Useful Post:
Sir MixAlot (01-15-2015)
Old 01-23-2015, 01:18 AM   #5
Rewards Points: 16
Great video, I just noticed this post after I posted a very similar thread.
AKBoater is offline   Reply With Quote
The Following User Says Thank You to AKBoater For This Useful Post:
Sir MixAlot (01-27-2015)
Old 01-27-2015, 07:17 AM   #6
Rewards Points: 106
Thanks for the very helpful video
How to trim a 6" circular permanent hole in drywall? amakarevic Drywall & Plaster 8 06-23-2014 08:25 AM
drywall ceiling repair after bathroom fire help nilewaves Drywall & Plaster 9 06-07-2011 03:33 PM
Repair hole in drywall installed on concrete optimizer Drywall & Plaster 5 04-18-2011 10:19 AM
Minor Drywall Repair leted_82 Building & Construction 3 10-11-2007 09:57 AM
I hope I don't have to tear down the ceiling brds16 Carpentry 9 04-30-2005 10:16 AM
