-   How To Guides (http://www.diychatroom.com/f98/)
-   -   How to remove the haze from your headlight. (http://www.diychatroom.com/f98/how-remove-haze-your-headlight-63300/)
brokenknee 01-31-2010 08:53 PM
3 Attachment(s)
I saw this on another forum that I am a member and was so impressed with the before and after photos I just had to try it. Here is the link to the thread where I got this information. http://garagejournal.com/forum/showt...ht+restoration
Anyone that has an older car or truck knows how hazy/oxidized the plastic housing on the headlight can become. It can get so bad as to effect the light output making it dangerous to drive at night.
To clean that haze off all you need is about a half hour of your time, a buffer and some aluminum paste. I purchased Mothers brand, the person that made the other thread used Mequire's. His headlights seemed to turn out better than mine; but that could be because he used buffer, while I used a buffing disc in my drill. It also could be because when I was doing it today the temp was only 9 ͦso the paste may have been freezing while I was trying to buff it out.
I wished my pictures would have turned out better, they really do not do justice to how hazy they were and how well they turned out. Click on the link to the other guys thread, his pictures turned out much better than mine.
Here is what I used.
Attachment 17336
This is what it looked like before.
Attachment 17337
This is what it looked like after.
Attachment 17338
jerryh3 02-01-2010 04:27 AM
Good tip. I do the same thing but use Meguiar's Plastx Polish.
CoconutPete 02-03-2010 08:29 AM
If you have none of the supplies on hand they are usually available in a "kit" as well which will include a small buffing wheel.
Millie.T.Cook 02-04-2010 03:24 PM
Great concept!
I never thought of that. I am going to do that right now. This is exactly what I needed for the drive home after work.
Thanks for sharing
MC
No advertising thank you
Moderator
Garage Detailer 02-05-2010 08:29 AM
If they are heavily oxidized, you can use 1000 then 2000 grit sandpaper before buffing. Mine turned out well with this method and they were really bad before.
Willie T 02-06-2010 08:25 AM
I did the same thing on my truck lights, my motorcycle, and my wife's car. I used 3-M polishing compound. I did it by hand and it took about ten minutes per lens. Try it on your taillights. They also get duller than you might suspect.
It even makes the vehicles look years newer. Works well on the 'chrome' plastic trim too.
FLORIDADIYDAD 09-02-2010 01:52 PM
Honda cars are darn near impossible
Aside from taking apart the front end of the engine compartment I have yet to find a way to polish my headlamp covers.
I drive a 2002 Accord and at night it's like my car has a squint on the left side. Getting dimmer by the day. Some local kids have come up with a mobile service that does nothing but buff these but they want $75 a pair and I'm too stingy to pay that much.:laughing:
comp 09-02-2010 03:11 PM
been thinking about doing a service like that ,,how do they advertise ???
PaliBob 09-02-2010 07:52 PM
Aside from taking apart the front end of the engine compartment I have yet to find a way to polish my headlamp covers........
In post #1, brokenknee included before & after pics. I would try his technique before I made a judgement call.
PaliBob 09-02-2010 07:58 PM
HF, sells a kit
I have NOT tried this
http://www.harborfreight.com/12-minu...kit-65938.html
ehoez 09-02-2010 11:25 PM
http://www.amazon.com/Professional-H.../dp/B001P97RHY
Thurman 09-05-2010 10:31 AM
I have not seen a mobile set-up around here, but it is a good idea, but there are two car washes that advertise this procedure. They only charge $39.99 for the set. How do these people come up with these $39.99 prices? Why not just charge $40.00 bucks and be done with it? I've done some of these for family and I use a combination of polishing compounds from 1600--2400 grit. I get these at an auto paint supply store and do use an orbital buffer. I only charge dinner. David
nap 09-05-2010 04:31 PM
the same reason the .99 was originally used; it is a psychological function. You aren't paying $40 for something, you are paying $30 some odd dollars. Even though is is only a penny, your mental recognition is that you are not breaching that next level.
I bought a kit (I think it was a 3M kit) that had a variety of sanding paper and then the polish and applicator. All used in a low speed drill. Worked great. Without the sandpaper, it would never have worked.
Red Squirrel 09-05-2010 07:12 PM
Good tip, I'll have to try this. just had a headlight replaced due to some guy running into me, and it looks so much nicer then the other one.
SnoBird 09-12-2010 06:32 PM
Thirty years ago, we took scratches and haze off of snowmobile windshields using toothpaste and a soft cloth. Give it a try.:yes:
