Originally Posted by Drhoda
So it is ok to "pour" poly on the floors?
I've always wanted to do it that way but was afraid it would cause bubbles?
You only want to pour as much as you can work with. Don't empty the can! Pour a line of finish along your starting wall, 6-10 inches away and use the t-bar mentioned in the original post to snowplough the finish as close to the edge as you are comfortable with. Use a brush along the edges first though, and overlap with the applicator.
Your t-bar should eliminate any bubbles.
