-   How To Guides (http://www.diychatroom.com/f98/)
-   -   How to Recoat (Sandless Refinish) Hardwood Floors (http://www.diychatroom.com/f98/how-recoat-sandless-refinish-hardwood-floors-139824/)
RhodesHardwood 04-09-2012 10:55 PM
Here is directions to restore wood floors that have previously been finished with a polyurethane finish using a sandless refinishing method. (Please Note: This process is not for all wood floors, since no actual sanding is done this process will not remove dents or dings that are deeper than the top finish layer)
The first step is to buff the floor using an electric floor buffer. You will want to use a white buffer pad a 220 grit sanding screen for this. 1 screen will typically buff about 200 square feet. If you are not experienced using a floor buffer, you may choose to use a square buffer. These vibrate rather than occilate, so they are easier to operate.
The buffing is meant to buff out surface scratches and abrade the finish so that a new coating will bond. The buffing is not meant to sand down the floors.
After throughly buffing the floors, the next step is to vacuum. It is a good idea to vacuum over every inch of the floor a couple times. After vacuuming, go over the floor with a micro fiber dust mop that has been dampened with mineral spirits. This will get any left over dust that the vacuum didn't pick up. Then let the floor dry from the mineral spirits.
Now you are ready to apply finish to the floor. To apply finish I reccomend an 18" T-Bar style applicator; Dura Tool makes a nice one. Pour finish directly on the floor and squeegee it back and forth working your way out of the house. It is best to do the edges with a foam brush.
Other Notes: This process is not ideal for floors finished with shellac or Aluminum Oxide finishes. To recoat these floors just buff the floor with a white pad only. Spray the floor with Bona prep and buff it into the floor. This product is meant to prepare these types of finishes so that a new coating will bond to the existing finish. After buffing just follow the rest of the steps listed above including vacuuming, cleaning and finishing.
Questions? Feel free to message me.
Scuba_any_time 07-30-2012 11:03 AM
In your original post you said "Other Notes: This process is not ideal for floors finished with shellac or Aluminum Oxide finishes." How do i determine if my existing floor is one of these?
RhodesHardwood 07-30-2012 11:37 AM
Chances are if the floor was not a prefinished floor it will not have an aluminum oxide finish. Here is an article I found that discusses how to determine what type of finish you have http://voices.yahoo.com/refinishing-...d-6882134.html.
If the floor was previously done in the past 10 years it probably does not have shellac. If you can not make a definite determination on the previous finish used, I would suggest to first coat the floor with a sanding sealer such a DuraSeal universal sealer, then coating with floor finish of your choice. This will seal up the floor so that a new coating will bond. Hope this helps
Drhoda 01-18-2013 11:05 AM
So it is ok to "pour" poly on the floors?
I've always wanted to do it that way but was afraid it would cause bubbles?
BuYersChoice 04-03-2013 01:31 PM
You only want to pour as much as you can work with. Don't empty the can! Pour a line of finish along your starting wall, 6-10 inches away and use the t-bar mentioned in the original post to snowplough the finish as close to the edge as you are comfortable with. Use a brush along the edges first though, and overlap with the applicator.
Your t-bar should eliminate any bubbles.
Marianna Fl. 05-13-2013 06:47 PM
Thank you for your posts on this topic. I bought a 110 year old (1902) home and know nothing about the 5000 sf of heartpine floors i have. How can i tell if they have a shellac or other coating on them?? Thanks, Ed
Seattle2k 05-15-2013 11:30 AM
:icon_rolleyes:The answer was already given to you.... http://voices.yahoo.com/refinishing-...134.html?cat=6
eliciasam1 06-17-2013 03:17 PM
Thanks for the thread, it'll be very helpful.
ptlandscape 07-07-2013 08:52 PM
I recently refinished my old hardwood floors and applied the second and final coal of polyurethane on it two days ago. I screened and wiped down the first coat of poly with mineral spirits and thought it looked pretty good at that point. Is it OK to screen and wipe down the final coat with mineral spirits or will it show scratch marks?
4reel 03-05-2014 07:26 AM
Minwax has a product out that is supposed to help floors last longer. Have you heard of it and what do you think about it?
taylorjm 03-05-2014 06:23 PM
My experience is to stay away from the minwax products. I've used their stains and polys for furniture and swore I'd never use it again. Go to a real paint store and get something good.
fortunerestore 03-12-2014 11:42 PM
Sanding and re-staining hardwood floors
I really appreciate the initiation of this thread. It is going to be very useful for my next project. Refinishing the hardwood floor is a tough job and needs precision too. Someone suggested me that using the 20s to 36-grade sandpaper at the beginning and gradually move toward 100 to 120 grit for the last round of sanding will be helpful and really it is. I need to know what measures can be adopted to change the color of the floors, I really need to change its color. Is it possible? How should I start re-staining my floor?
