How To Make A Planer Knife Sharpening Jig - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 09-16-2011, 08:14 AM   #1
the Musigician
DangerMouse's Avatar
How to make a planer knife sharpening jig
I whipped up this planer knife sharpener jig to try to save a few $$$.
It works far better than I had hoped!
A 2" X 3" X 12" block of oak, a drill and an old table saw is all it took!
Note edge sharpened (yellow arrows) is slightly beveled away. Perfect.....
DM
Old 09-16-2011, 10:05 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 508
How does it work DM?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 09-16-2011, 11:27 AM   #3
the Musigician
Pretty good! I just went out and ran up this 2" oak plank from a log I split up from my woods. Turned out fine!
DM
Old 09-16-2011, 11:39 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 508
Okey Dokey then, let me rephrase the question. Can you explain how it works and how you built it, what angles etc, what are the wing nuts for? I am a little thick so please just overlook me. I really do want to know, my way of sharpening is slow as the dickens.
Jim
Old 09-16-2011, 11:55 AM   #5
kwikfishron's Avatar
Rewards Points: 770
How about a demonstration video DM???
kwikfishron is online now   Reply With Quote
Old 09-16-2011, 12:39 PM   #6
the Musigician
It's either 42 or 48 degrees on the angles, I just eyeballed it.
The wingnuts lock the blades in the slots while you work them.
Forgot to mention the shims inside that are not seen.
DM
Old 09-16-2011, 06:29 PM   #7
Ole Wood Worker
BigJim's Avatar
Rewards Points: 508
I got ya, that is nice. Do you use water stones, oil stones or sand paper?
Jim
Old 09-16-2011, 07:06 PM   #8
the Musigician
Dang! Those are way better ideas than the front sidewalk!
DM
Old 09-16-2011, 07:43 PM   #9
Ole Wood Worker
BigJim's Avatar
Rewards Points: 508
DM
Yow but you can sharpen your blades and ride your bike at the same time.
Jim
Old 09-16-2011, 08:17 PM   #10
DIY staff
Rewards Points: 7,174
Danger!
Are you going to tell us or WHAT??
This isn't like the trick box is it?---
Old 09-17-2011, 06:47 AM   #11
the Musigician
Tell you....... what?
Sandpaper?
DM
Old 09-17-2011, 07:01 AM   #12
DIY staff
Did you also post a thread about building a kayak trailer for a bicycle?
Old 09-17-2011, 07:44 AM   #13
the Musigician
did you also post a thread about building a kayak trailer for a bicycle?
Dm
Old 09-17-2011, 11:03 AM   #14
Ole Wood Worker
BigJim's Avatar
Rewards Points: 508
Sandpaper?
DM
Jim
Old 12-26-2011, 05:56 AM   #15
the Musigician
Just a quick update. I've sharpened 2 sets a few times now and they still perform well.
I HAVE noticed they don't seem to last as long per sharpening as when new.
DM
recommend a book nvr2low Drywall & Plaster 9 12-21-2011 11:37 PM
How to make a custom floor transition chuckp27 Flooring 9 12-02-2011 10:48 AM
How to make recessed shelving DesignDuoBlog How To Guides 0 08-30-2011 04:20 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Do they make this? Malcolm Roofing/Siding 3 10-13-2007 11:23 PM
