How To Make A Candle-Powered Space Heater - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 03-04-2013, 06:53 PM   #1
How To Make a Candle-Powered Space Heater
Here's a tutorial I made on how to make your own space heater powered by only a candle. It works pretty well for small spaces - not a whole house.
Check it out, I have a video tutorial included. All you need are a few terra cotta pots, nuts, washers, and a bolt. Costed me about 4 bucks total. Frugal to the max!
Here's a picture:
-Matt
Last edited by beenthere; 10-03-2013 at 08:24 PM. Reason: Removed link to Off site blog
ByWayOfBicycle is offline   Reply With Quote
The Following User Says Thank You to ByWayOfBicycle For This Useful Post:
jamie86 (05-29-2014)
Old 03-04-2013, 07:10 PM   #2
Rewards Points: 13,446
Is that UL approved?
Old 03-04-2013, 07:13 PM   #3
No, it definitely has a possibility of starting a fire, because it gets so hot.
Sue me
Old 03-04-2013, 07:34 PM   #4
DIY staff
Rewards Points: 7,174
That is a neat way to distribute the heat-----I suggest a fire proof tray----but still clever.
Old 03-18-2013, 04:55 PM   #5
Always learning...
fetzer85's Avatar
Rewards Points: 262
Here's a turtorial I found from 2008 with the same info.
http://www.greenoptimistic.com/2008/.../#.UUeNGxyG0xE
fetzer85 is offline   Reply With Quote
The Following User Says Thank You to fetzer85 For This Useful Post:
oh'mike (03-18-2013)
Old 10-01-2013, 09:50 AM   #6
I can't see the advantage of this. It's not cost effective, it's not efficient, and it's not very useful. Am I missing something?...like you are trapped in a cold room with nothing but some flowerpots and a candle?
Solarboy is offline   Reply With Quote
Old 03-03-2014, 03:02 AM   #7
Rewards Points: 212
Uhhh, all those pots aren't going to make the candle produce any more heat than a candle burning all by itself.
A Squared is offline   Reply With Quote
Old 03-03-2014, 01:26 PM   #8
Oso954's Avatar
Rewards Points: 990
No it does not, but it Traps a lot of the heat in its location. If you are close it, you will feel warmer than if the candle heat got distributed around a large room.
But I don't think it is cost effective and it does have a fire risk.
Oso954 is online now   Reply With Quote
Old 03-23-2014, 11:16 AM   #9
this is very interesting...thanks for the share.
mbender2004 is offline   Reply With Quote
Old 03-24-2014, 04:14 PM   #10
Rewards Points: 948
Will change the heat from convection to radiant. I am not sure why that would matter, but I suppose...
Toller is offline   Reply With Quote
Old 03-24-2014, 05:23 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,450
The 'typical' candle puts out about 50-77 watts of heat energy.
The only thing that 'hat' is doing for you is slowing down how fast the heat rises up.
50w is 50w....space heater or no space heater.
Old 03-26-2014, 11:51 PM   #12
Rewards Points: 498
If you had no heat in your house, say there was a power outage for a few days, you could easily close-off one small room to stay in. Keep 4 or 5 of these things going and it would at least take the chill off. Better than nothing!
gma2rjc is online now   Reply With Quote
Old 03-27-2014, 03:54 AM   #13
An old Tradesmen
Rewards Points: 6,846
I'd rather use the below for heat in that case.
http://www.wayfair.com/Mr.-Heater-4-...FRQV7AodZyYASw
Old 03-27-2014, 08:14 AM   #14
Rewards Points: 2,634
Heating a house with open flames or propane combustion indoors sounds like a couple of good ways to get CO poisoning.
SPS-1 is offline   Reply With Quote
Old 03-27-2014, 04:19 PM   #15
An old Tradesmen
The one I linked to, at worse will put off as much CO as a propane range/oven.
Tags
candle , diy , frugal , space heater
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Carve toekick to make heater vent grill. Bad idea? mudworm HVAC 0 08-31-2011 12:27 PM
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
How to Space Water Heater Flue Vent from Outside Wall? austinbirdman Plumbing 1 03-12-2007 10:28 AM
Space Heater And K-1 Kerosene bobo General DIY Discussions 7 10-25-2006 10:38 PM
