How To Lift Your Lawn Tractor - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > How To Guides
Old 06-20-2015, 11:53 PM   #1
Rewards Points: 4,424
How to Lift Your Lawn Tractor
for deck cleaning and it's no business of OSHA how I do some things around the ranch.
The Following User Says Thank You to SeniorSitizen For This Useful Post:
ron45 (06-21-2015)
Old 06-21-2015, 09:16 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 5,858
Unless "the ranch" is a business with employees OSHA doesn't care but as long as you use rope that is adequately strong and your means of securing the tractor in the raised position is dependable I see nothing wrong with the idea. In fact it looks quite creative and actually safe (as long as the above mentioned issues are followed).
Old 06-21-2015, 10:08 AM   #3
OH, I failed to show the home made rope I made with a home made rope maker to fasten the snatch block to the shade tree. But it's a good one. I just tested it.
Old 06-21-2015, 11:41 AM   #4
Rewards Points: 1,884
if it were my head under there, there would be blocks under it,
let us know how your project turns out!
Yodaman is online now   Reply With Quote
Old 06-21-2015, 12:30 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 3,150
Need to clean under mine today. Think I will run it up some ramps.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 06-21-2015, 01:03 PM   #6
Rewards Points: 1,941
I just flip mine up onto its built in stand.
When I was 16 I worked under an engine and transmission held up by a chain hoist supported by a single 12 foot long tier rail (2x10 x12, barn terminology). Somewhere along the way I discovered mortality so I'm with blocks or jack stand comment above.
Colbyt
I often use the Thanks button as a ditto button or +1 button.
Colbyt is offline   Reply With Quote
Old 06-21-2015, 03:40 PM   #7
Remodeler
Rewards Points: 214
It only takes about a minute to drop and roll the deck out from under my X495 diesel garden tractor. It's a pretty fast and simple operation on most modern JD mowers.
iamrfixit is offline   Reply With Quote
Old 06-21-2015, 04:34 PM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 1,800
I hope you took the keys out of the truck....
Old 06-21-2015, 06:24 PM   #9
Davejss's Avatar
Rewards Points: 678
I just take off the mower deck.
Davejss is offline   Reply With Quote
Old 06-22-2015, 05:13 PM   #10
Rewards Points: 1,908
I suppose if you are just standing back spraying the underside with a hose that will work But no way I'm putting any part of me in it's fall path.
The Following User Says Thank You to jogr For This Useful Post:
JD367 (07-05-2015)
Old 06-24-2015, 08:36 AM   #11
Rewards Points: 362
No way am i working this way. I'd rather take the deck off, but if i just "have" to get under the mower, i use my modified motorcycle lift.
One of the benefits of a Kubota F-series mower i am eye-balling is, that the deck is up front and tilts up for blade sharpening and cleaning.
78Vette is offline   Reply With Quote
Old 06-24-2015, 09:24 AM   #12
Rough Rooster's Avatar
Rewards Points: 114
My lift:
One of the handy things I have done for my shop so I can still work in my old age.
RR
Rough Rooster is online now   Reply With Quote
Old 06-30-2015, 12:18 PM   #13
Brainbucket's Avatar
Rewards Points: 246
Nice Rooster! I just use a floor jack to get rid of crap that's stuck under the mower but if I need to do more that change a blade, I pull the deck out from under tractor.
If you first donít succeed, get a bigger hammer!
Brainbucket is offline   Reply With Quote
Old 07-02-2015, 02:37 AM   #14
Stanley Johnson
Rewards Points: 2
How will you take off the mower deck?
Begather is offline   Reply With Quote
Old 07-02-2015, 04:35 AM   #15
DIY staff
Rewards Points: 6,676
It depends on the tractor--but removing a deck can usually be done without tools,by pulling off some retaining clips and removing the retaining pins---
You might want to start a new thread about 'removing a mower deck'--good subject--Mike--
Lawn Tractor Service Ramp? RCrosby257 Tractors & Mowers 6 05-11-2012 01:05 PM
Lawn Tractor Has No Power Smoke Tractors & Mowers 10 04-07-2012 11:52 AM
lawn tractor problem copseycliv Landscaping & Lawn Care 1 06-25-2011 10:32 AM
cant make decision on lawn tractor oldrivers Landscaping & Lawn Care 2 05-31-2011 09:45 PM
Lawn Tractor Battery WirelessG Landscaping & Lawn Care 17 05-10-2011 10:41 PM
