How To Install Drop Or Suspended Ceiling. - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > How To Guides
Old 11-12-2014, 01:27 PM   #1
Rewards Points: 6
How to install drop or suspended ceiling.
This was the first time installing a drop ceiling I watched this video prior to doing the install. http://youtu.be/PAvDlRbTHoI
Planning prior to making any cuts for the main runs is essential as you don't want to have a short edge on one side of the room and a long edge on the other side of the room try and make the edges similar for aesthetics. A mistake that I made is that I went to close to the floor joist I only left about 2 to 3 inch gap between the drop ceiling in the floor joist I would recommend leaving at least 4 inches as it was difficult getting a lot of the tiles in place.
The first thing that I did was go around the room with a 4 foot level and mark off for the J channel (piece that is screwed into the wall) I believe it's called. I measured and cut two main runs perpendicular to the floor joist. When you measure and cut the main runs they have a spot for the cross pieces every 6 inches use these to calculate your edge sizes. On one side of the room I had had a 21" x 17 piece I need a set of the room and of having a 20 x 17" piece. I attached the 4 foot and 2 foot pieces to square everything up. I used 2'x2' tiles and I added insulation into the floor Joyce for soundproofing from upstairs. Project took approximately three hours to complete.
jigger is offline   Reply With Quote
Old 11-12-2014, 01:48 PM   #2
jproffer's Avatar
Rewards Points: 586
Looks good.
One thing though that I noticed made it easier to get the tiles in, was to place them as you go along.
Put up the angles on the walls, put up all the mains, then as you put in the 2' or 4' cross pieces (in your case 2' is your only option), put the tile into the space as you go along. You only have to "work in" the last row.
None the less, all that matters is that it's done and looks good....and yours does.
jproffer is offline   Reply With Quote
Old 11-12-2014, 01:58 PM   #3
Rewards Points: 6
I forgot to mention that I did remove some cross pieces and placed tiles then replaced cross pieces. It would have been easier your way as getting the cross pieces out once they are clicked in they are very annoying to get out.
Old 11-12-2014, 02:26 PM   #4
jproffer's Avatar
Rewards Points: 586
Yes they are . Doable, but a big PITA.
Old 01-29-2015, 08:42 PM   #5
Rewards Points: 14
Jproffer,
I was wondering, I have a suspended ceiling with old 2x4 ceiling tiles and office setting fluorescent lights. Can I just remove my old ceiling tiles and replace with new ones? Can canned lighting be utilized instead of the fluorescent lighting?
Thanks,
Keith
keithvent is offline   Reply With Quote
Old 01-30-2015, 12:56 AM   #6
Rewards Points: 674
Originally Posted by keithvent View Post
Jproffer,
Yes to both
Anti-wingnut is offline   Reply With Quote
Old 01-30-2015, 01:02 AM   #7
Rewards Points: 674
Looks good, but.....
You can use those lights (or buy new purpose built) and place then in the center of the tile. They are partially supported by the tile, but hanger wires pick up the majority of the load. You can also turn the duct outlet 90* to horizontal and run a short piece of flex to the diffuser, which again has support wires to structure.
It would improve the look 1000%
Old 02-07-2015, 07:14 PM   #8
Rewards Points: 6
True but it would be a huge pain. The lights are new build pots attached to the floor joists and one on the front right has limitations to its location due to obstructions in the floor joists. The air run could be moved rather easily and I might take that on when I do the other room.
Old 02-12-2015, 07:09 PM   #9
Rewards Points: 18
Will give this a go, thanks.
nysvip is offline   Reply With Quote
Removed kitchen drop ceiling splicing electrical, j-boxes?? dzl13 Electrical 1 01-25-2014 11:51 AM
Unusual Framing for Drop Ceiling? jeffb99 Building & Construction 8 03-23-2013 03:41 PM
Newb DIY'er -basement drop ceiling question mike dub Remodeling 3 02-18-2013 08:37 AM
Suspended Ceiling / Ductwork Branden Building & Construction 1 02-01-2013 08:58 AM
Hanging light fixture from a suspended ceiling? rjniles Electrical 11 08-21-2012 12:52 PM
