Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 09-26-2010, 11:07 PM   #1
How to Install Cabinet Hardware Uniformly
I know this isnt the first time someone has done this and Im sure everyone has their own process of doing this, but I thought I would share mine.
I recently finished a house remodel and moved in about a month ago. My girlfriend has been asking me to install this hardware in the kitchen for a while and I finally got around to doing it.
These handles are long and being as long as they are if they are not square with the door they would stand out badly. To combat this I made a simple jig to make sure the holes I drilled were the same each time. I used a piece of plastic filler from storefront metal from my work and cut on of the profiles off:
I then measured where the holes needed to be and figured out where I wanted them in relation to the door. I transferred those numbers onto the plastic piece. I used tape so I could see the marks easier.
A good trick I learned when measuring from a line (not hooked or bumped onto something) is to set the tape on 10 inches and that now becomes your 0 inch mark, so in this case 16 5/16" is 6 5/16". It works good on small things but can run into trouble if you are doing larger measurements and rushing (Ive made the mistake of cutting either too big or too small before ):
Next I did the same thing for another set of holes on the opposite side of the plastic. I marked each hole with letters so I could easily see what hole to mark and I flipped the letters so I could tell if I was doing something wrong. I know it would have been easier to center the holes on the jig but I had already cit the plastic piece at work so I had to work with what I had:
This picture demonstrates the marking of the holes in relation to an already installed handle. To make each the same I bumped the edge of the template onto the edge of the door and then lined up the bottom of the template to the bottom of the door:
Also before I started to avoid a mess of packaging from the hardware in my kitchen and to speed up the install I took everything out of the packaging and separated it all before I drilled the first hole, it helps a lot to be organized:
jegolopolli is offline   Reply With Quote
Old 09-26-2010, 11:14 PM   #2
I did not drill through the template, I marked the door through the template with a marker. After I drilled the holes I counter sunk the back side so the screw would sit just below the profile of the door. The counter sunk hole was wider than the screw so to hide this I took a black permanent marker to the outside edge of the holes:
There was one unforeseen problem I ran into. The cabinets were old and we sanded and stained them when we did the remodel and used all of the old hinges, but I did replace all of the screws. Some of the doors were uneven with each other, meaning one door might be sitting as much as an 1/8" lower/higher than the other. This was all done by who ever installed them originally. You cant tell initially but if you look close you can. So to avoid making it more obvious with the handles I cheated the handle up or down accordingly instead of always lining the template up to the door. It worked pretty well.
Before and after:
The Following 2 Users Say Thank You to jegolopolli For This Useful Post:
PennJersey (03-13-2011), shumakerscott (10-13-2010)
Stanley Pocket door hardware install P14ZZ4 Carpentry 15 11-03-2010 11:06 AM
Fixing Cabinet Hardware Installed Uneven Nayr Carpentry 13 09-14-2010 09:13 AM
Drawer Slide for Cabinet w/o back george0410 Carpentry 2 04-08-2010 06:53 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
