How To Hang Wallpaper - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 11-16-2014, 07:42 AM   #1
Rewards Points: 106
How to Hang Wallpaper
Tips for Success:
The success of hanging your wallpaper, as well as the ease of taking it down are totally dependant on how well you prepare your walls!
SMOOTH. Make sure you fill all cracks and holes using spackle. Sand until you have a smooth surface with a medium grit sandpaper.
CLEAN. Wash and rinse walls to remove grease and dirt. The surface must be clean and free of mildew, grease and stains.
PRIME. For best results, prime all wall surfaces with a high quality primer-sealer before installing wallcovering. Priming properly is key to easy removal later.
1. Turn off power to switches and outlets.
2. Draw a vertical guideline (plumb line). Put this approximately 19” away from
the corner.
3. Follow label instructions for soaking the rolled strips.
4. Slowly draw out the soaked strip.
5. “Book” the strip by folding the ends towards the center; paste side to paste side.
6. Apply the first strip with its edge against your vertical guideline (plumb line).
7. Smooth each strip with a smoother or sponge.
8. Apply remaining strips in the same manner.
9. Clean as you go with sponge and clean water.
10. Paper over doors and windows; cut excess with scissors.
11. Cut diagonally through the waste portion towards the corner of the door
or window.
12. Trim the excess with guide and knife
13. Trim excess at top and bottom with metal edge and knife.
14. Make sure that power to switches and outlets is off . Paper over them, then cut paper clear of wires and fixture box.
15. Start by making a small slit in the paper at the center of the outlet. Cut diagonally towards the corners, then carefully trim around the outlet so that when you replace the cover plate, no cut edges will be visible
RHeat is offline   Reply With Quote
Old 11-16-2014, 03:59 PM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 310
I don't know where to start but first off the primer must be a wall paper primer, NOT a paint primer. I could go on critiquing this post but just don't have the time.
The Following User Says Thank You to chrisn For This Useful Post:
RHeat (11-16-2014)
Old 11-16-2014, 04:16 PM   #3
Rewards Points: 106
I don't know where you see the word "Paint primer" but thanks anyways.
Old 11-17-2014, 02:10 AM   #4
chrisn's Avatar
Rewards Points: 310
. For best results, prime all wall surfaces with a high quality primer-sealer before installing. Priming properly is key to easy removal later.
usually means paint primer
means wall covering primer
as for the rest of it, some might work with a pre pasted paper but with a normal paper that you have to paste, not so much
#2 I do not get at all
10 and 11 and 15 I don't get either
but I do this most every day , so what do I know?
You can certainly follow all these steps but do not for a moment think that this is wall papering gospel
Gymschu (11-17-2014)
Old 11-21-2014, 11:11 AM   #5
Rewards Points: 402
Applying wallpaper is as tricky as applying a screen guard on a Smartphone; you ruin all the show if you have even a slightest of the wrinkle on it. Firstly you need to clean the walls. Once your walls are clean, then you are good to go, i.e., adding adhesive to the wall and wallpaper. Applying adhesive to the both isn’t as difficult as pressing the wallpaper against the wall carefully without getting even a single bubble or wrinkle while you finish sticking the entire piece of the paper.
fortunerestore is offline   Reply With Quote
Tags
wallcoverings , wallpaper
Peeled wallpaper down to bare paper facing on drywall, can I hang new wallpaper? PICS tunabreath Painting 5 08-05-2012 09:18 PM
Painting over wallpaper - no other option - How to proceed kuj0317 Painting 15 07-25-2011 04:25 AM
Wallpaper removal or primer? Should I put up new wallpaper instead? Aqua Painting 1 04-06-2011 04:36 AM
painting and wallpaper residue jayoshi Painting 1 09-13-2009 05:03 PM
Can I paint over wallpaper primer? CLM Painting 3 07-15-2009 03:40 AM
