How To - Get/make Free Flooring! - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 06-05-2011, 08:56 AM   #1
the Musigician
DangerMouse's Avatar
How to - get/make free flooring!
At our old home, we installed a new furnace and a new roof. This meant the old chimney through the middle of the house was no longer needed. We (I) installed a dropping staircase in the ceiling to access the attic, and we removed the chimney to below floor level. (The rest was too integrated in the rooms below to mess with) Then, throughout that summer, I went around on junk days and collected ANY 2" X *whatever*" I could find. Water bed frames were a big help, but any scraps of 2x4s or 2x6s or whatever got picked up and screwed down to the floor up there. (All butted ends screwed down tight) I ended up with a very thick, strong 12' X 30' floor by the end of the summer and then found some used carpet that was in excellent shape...... but it was 2 different colors and neither was big enough to do the whole job. Solution? I cut it all up into 2' squares and just glued it right to the flooring with PL construction adhesive. (Go ahead and laugh, we were new at that kind of stuff and flat broke at the time, unlike now, when we're just poor.) The 'checkerboard' look was nice! The wife liked it and it's still up there as far as I know. I added windows at each end and threw up some paneling and it's being used as an extra bedroom still. I even built in a desk area at the front end with scraps for a homework area.
This is just a thread to show how using a little ingenuity can save you big $$$. The only thing that cost us was the screws and glue! ....Ok, and the staircase too I guess.... but I got that for $40.00, so it wasn't too bad.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
BigJim (06-05-2011)
Old 10-16-2011, 11:48 PM   #2
Rewards Points: 968
can you post some pics. this sounds interseting!
federer is offline   Reply With Quote
Old 10-17-2011, 04:02 AM   #3
the Musigician
I would, but we don't live there any more.
DM
Old 10-17-2011, 05:45 AM   #4
jburd964's Avatar
Rewards Points: 166
Are you currently residing in a park not for from Wall Street??
I did stay at Holiday Inn Express last night.
Gun control isn't about guns, IT'S ABOUT CONTROL.
jburd964 is offline   Reply With Quote
Old 10-17-2011, 05:50 AM   #5
the Musigician
No, I am not.
DM
Old 10-17-2011, 08:20 PM   #6
jburd964's Avatar
Rewards Points: 166
Just having fun with you. Sounds like a good job. I try reusing materials if I have them on hand. I never trash anything usable and if I can repair a frayed cord or glue r weld it back together thats great.
Old 10-17-2011, 11:59 PM   #7
Rewards Points: 968
DM
congrats! i am glad you upgraded
Old 01-11-2012, 04:50 PM   #8
Wow, way to bargain hunt with your project. Can't believe you got a staircase for $40. Where'd you find that gem?
metal is offline   Reply With Quote
Old 01-11-2012, 05:18 PM   #9
the Musigician
Local lumberyard. Before it was driven out of business.....
DM
How to cut exhisting flooring in the doorway jjpar Flooring 8 10-26-2011 11:01 AM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 08:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
Basement flooring options.. Tommy2 Flooring 9 02-14-2009 07:06 PM
no glue, no nails wood flooring - little help? reds_21 Flooring 2 02-13-2009 11:32 AM
