How To Fix A Noisy Dryer - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 04-03-2015, 06:55 AM   #1
How to fix a noisy dryer
If your clothes dryer is incredibly noisy whenever you use it, it might be time to look at a few parts. Here are some of the noises that your dryer might be making and the parts that might be causing them.
Scraping metallic sound: drum glides or slides
The drum glides and slides provide support and a smooth surface for the dryer drum to rotate on during operation. When the drumglides wear down from use, there might be a scraping, metal on metal sound produced. Replacing the drum glides will solve this problem.
Rumbling or thumping sound: worn drum rollers
Drum support rollers support the dryer drum as it spins. Over time, the rollers wear down and the shape of the rollers change and become elongated, forcing the drum to spin up and down on the non-round wheel surfaces. Drum rollers come as a set and both should be replaced.
worn Idler Pulley Wheel 6-3700340
Squeaking or squealing noise: Belt or Idler Pulley
Dryer belts can become worn and brittle from age and use. Worn belts should be replaced. Also inspect the idler pulley, which provides tension on the drum belt. The idler pulley should be able to spin freely on the shaft. Sometimes lint and hair can build up around it, causing it to squeak. The part can also become worn from use and should be replaced.
Other parts to check out that might be causing noises include the blower wheel, drum bearings, dryer motor and fan assembly.
EAP2015 is offline   Reply With Quote
The Following User Says Thank You to EAP2015 For This Useful Post:
Windows on Wash (04-03-2015)
Old 05-21-2015, 06:17 PM   #2
Rewards Points: 16
Thanks for the tip
John7530 is offline   Reply With Quote
Tags
dryer
Another Dryer Question 3 to 4 wire John3rd Electrical 15 07-29-2015 01:10 PM
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 11:00 AM
Help with Electric 240v for a Dryer Sunshine807 Electrical 17 10-21-2011 10:35 AM
Noisy Kenmore Dryer Skeeter01a Appliances 2 02-22-2010 07:05 PM
dryer noisy econdave Appliances 6 05-30-2007 02:39 PM
