Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 05-12-2009, 09:27 AM   #106
gravity always wins
The blue can does not have a UL rating. If the building inspector is telling you to use a product without a proper rating or UL listing in place of one that does, then he is setting himself up for a great deal of liability, regardless of what your torch test shows. Unscientific tailgate product tests performed by amatuer fire protection specialists don't hold up in court. Insurance companies love those. They can weasel out of a claim easier when a homeowner uses an untested, unrated product in place of the proper one. On the other hand, if you had a problem. you might be able to sue the inspector for having told you to use the wrong product.
Old 05-12-2009, 09:40 AM   #107
In way over my head.
Clutchcargo's Avatar
That's a good point about the UL listing. The next time I see the inspector, I'm going to ask him about that.
You'll never be sorry you bought the best.
Clutchcargo is offline   Reply With Quote
Old 05-12-2009, 10:22 AM   #108
Building codes guy, Mod
thekctermite's Avatar
Maintenance 6 is 100% right, your inspector is wrong in giving the option he's giving. Listings, my friend. Listings.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 06-04-2009, 03:37 PM   #109
Project Addict
tjeieio's Avatar
Default Vertical blocking
Okay - I have read this entire thread and have learned a great deal. Thanks for posting the excellent photos. One thing I have not fully understood is how to install the vertical @ 10' blocking. I have a 1" gap between my concrete basement wall and the 2x4 framing. If I stuff fiberglass insulation or rock wool behind one of the studs, how is that supposed to stay there? On the other hand, if I use P/T lumber or green sheetrock, how does this create a tight fit? Thanks in advance.
tjeieio is offline   Reply With Quote
Old 06-05-2009, 10:44 AM   #110
You've got a couple options when doing this.
The first is to use unfaced fiberglass insulation. Roll it up and pack it in very tight. When packed in it definitely won't go anywhere. Rock wool is pretty tough to pack in comparatively, unless you use something to retain it. In my experience most jurisdictions will allow fiberglass, since the code allows it in other fireblocking applications.
As you mentioned the other option is to use another piece of wood. Personally I wouldn't necessarily use treated material. Regular untreated 2x dimension lumber is fine, assuming it doesn't physically make contact with the concrete. Either wood you choose, there will be a bit of a gap...Perhaps less than 1/8". Such gaps MUST be sealed tight with orange fireblocking foam, which does a good job of bridging the gap.
Old 06-05-2009, 12:09 PM   #111
Project Addict
tjeieio's Avatar
Default Fire blocking
Thanks for the quick reply. It makes some sense now. Hopefully our building dept will okay the fiberglass use. Waiting for my plan review.
Old 07-19-2009, 11:25 PM   #112
Default Fireblock Help
I wish I would have stumbled upon this before I started to frame my basement. I have some questions on the best way to fireblock my basement. I had blanket insulation on my foundation walls. When I framed my perimeter walls, I failed to get the wall as tight as I would have liked to the blanket insulation. The result is anywhere from a .25 to 2 inch gap behind my studs and a gap behind the top plate. What would be the easiest method to fireblock this dead space? I was thinking of just buying thicker bat fiberglass insulation for between the studs to take up that extra space. Does that count for fireblock to stop fire from going vertical or horizontal? Or do I still need wood or insulation wedged in behind the top plate and behind a stud every 10' horizontally?
I also have a soffit and reading this thread I will need to 2X block between the studs to keep a fire from rolling from vertical to horizontal in the soffit. However, do I have to block the joist spaces where my soffit
meets the ceiling (where the red X's are)?
avshockey is offline   Reply With Quote
Old 07-20-2009, 02:07 AM   #113
Project Addict
tjeieio's Avatar
Default Fireblocking with insulation
Turns out the city is requiring R-21 insulation in my perimeter walls, plus waterproofing. As such, the 1 inch gap will be filled tightly with the fiberglass batts (3 1/2" studs plus 1 inch = 4 1/2") since the batts are 5 1/2" thick. Telephone conversations suggest this will suffice for horizontal blocking. Vertical blocking will still require the insulation to be installed between floor joists and above the top plate.
Old 07-20-2009, 10:20 AM   #114
Avshockey-
The joists above your soffit do not require fireblocking. You can insulate them if you wish though. Blocking the stud spaces from opening up into the soffit is required, as stated.
The gap between the foundation wall and the framed wall at the top plate is a judgement call. I would require that you pack the gap at the plateline with fiberglass. Simply using thicker batts fills the gap at the stud spaces but not behind the studs themselves. I'd suggest packing it with fiberglass just to be safe.
More On This Topic
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. When you're framing your basement by yourself, or if you've hired someone else to do it, one thing to think about is the spacing that you will use to space... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be talking about insulation tips. Now that our wall is fully framed in, we can go ahead and insulate. When buying insulation, there is a couple of things that you want to look for... Read More »
Hi I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. The insulation is a project that's very simple and and something I would actually suggest for a homeowner to try to do themselves. In this home here we... Read More »
Insulation lowers energy costs and cuts down on noise. Most homes have garages with insulation between only the garage and an exterior house wall. Today, more homeowners are choosing to insulate their garages and turn the extra space into a shop or... Read More »
Hi, I'm Jeremy Blackwell. I'm here today to help you get started on your basement remodel project. The schedule that you'll use when finishing a basement is very similar to the schedule that you'll use when finishing a home. In fact, it's almost exactly... Read More »
framing material estimate maydoug Building & Construction 38 06-12-2009 03:32 PM
Double Framing on old Garage? bofusmosby Carpentry 1 11-25-2008 07:36 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 11:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 10:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 06:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
