Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 01-31-2009, 11:37 AM   #31
Building codes guy, Mod
thekctermite's Avatar
Originally Posted by Scuba_Dave View Post
Good point
Can you install a PVC pipe & cap it & does that meet fireblock requirements??
You beat me to it. That's the Murphy's law pipe. Totally fine to do that. Very common in TV rooms with ceiling projectors or when audio/video components are in another area.
The building code is a minimum standard, and merely meeting it instead of exceeding it equates to building your project to the worst standard that the law will allow.
thekctermite is offline   Reply With Quote
Old 01-31-2009, 01:52 PM   #32
I've thought of putting 3" pvc through the firestop... but honestly, I wouldn't want to cap it. If I cap'd it, then I would have to tear the walls apart again next time I added/changed cables. Obviously, that would defeat the firestop. Slightly better I suppose would be to stuff fiberglass into the pvc, perhaps in addition to fire-caulk around the outside of the pipe.
If you did cap it, do people drill a hole through the cap to allow the wires through?
DIY_JC is offline   Reply With Quote
Old 01-31-2009, 02:03 PM   #33
Extreme DIY Homeowner
Scuba_Dave's Avatar
I was thinking that the caps would be in an area that would be accessible. IE basement to attic. For me I have a PVC pipe going from the basement to a knee wall area on the 2nd floor. I can then run wire to the Master bedroom, 2nd bedroom, or bathroom. The dormer on the back prevents easy access to the other 1/2 of the rooms. When I redo the kitchen I want to add a PVC access pipe for the addition
Old 02-02-2009, 02:19 AM   #34
Are you going to list the temperature requirements for various parts of the project, such as the temps around B vent, smoke pipe, chimenys? And the UL ratings such as E84?
When you are done with this little project, are you going to do one on Fire Stopping? Especially in commercial jobs.
fireguy is offline   Reply With Quote
Old 02-02-2009, 10:48 AM   #35
The fireblocking requirements I'm discussing here are based on R602.8 of the International Residential Code. ASTM E84 and UL 273 are surface burning tests that don't really come into play for this application because R602.8.1 specifically specifies the allowable materials for residential fireblocking (wood, plywood, sheetrock, etc).
Clearances to gas vents, fireplace vents, and chimneys are often an issue with firestopping materials. I'll try to get pics to demonstrate that as this thread progresses. B-vent clearances have already been discussed.
As for another thread on firestopping, I'd like to do one, but it really wouldn't be beneficial for most on this site since we're geared toward residential DIY. In this thread I do plan to eventually touch on intumescent caulk and its virtues in the garage to maintain the required fire membrane at penetrations.
Old 02-02-2009, 01:36 PM   #36
RDS
Thank you for this, termite. I recently spent a lot of time puzzling over fireblocking guidelines for my DIY bath remodel, and what you've provided here is clearer than anything else I found.
RDS is offline   Reply With Quote
Old 02-02-2009, 02:55 PM   #37
gravity always wins
Originally Posted by gma2rjc View Post
KC - I guess I'm confused about the purpose of fire foam. For example, the Great Stuff Fire Blocker. It wasn't a good idea to use it for sealing around a hot vent that exceeds the foams temperature limit of 140 degrees F. How does it serve as a fire blocker if the heat and flames of a house fire exceed 140 F?
Firestop products work in one of two ways. Intumescence or endothermy. When an endothermic product is exposed to fire it develops an insulating char on the surface. The char protects the material beneath it from further attacks by fire. Foams are endothermic. The other method is by intumescence. In this method, when the firestop product is exposed to high heat, it expands to fill any gaps, thus preventing the spread of heat and smoke. Firestop caulks and sealants can be either endothermic or intumescent. If you were to expose a firestop product to relatively high heat under a non fire condition, it would activate the fire proofing properties and expend thier usefullness. Further, firestop products are formulated to activate and provide protection during a relatively short timespan. Continued exposure to a moderate amount of heat over a long timespan is not what they were designed for.
Old 02-02-2009, 03:18 PM   #38
No problemo. Glad it helped. Trust me, I see the puzzled looks that builders give me when faced with fireblocking, so your average DIYer doesn't have any idea what to do.
Sometime soon I'll get some more pictures to get into further detail on various fireblocking situations.
Old 02-02-2009, 03:39 PM   #39
Interesting. It is my understanding that intumescent products expland (or intumesce) when heated, providing an endothermic barrier. Although the fireblocking foams do posess limited endothermic properties, they're not on par with an intumescent product. That's why they are not listed for firestopping, just fireblocking.
As far as firecaulks/fire sealants for firestopping go, there are intumescent products and non-intumescent products. The way I understand it, both perform endothermically to prevent the passage of fire for the listed time of the assembly, even only one expands.
I can tell you for sure that the fire foam doesn't do very well against a propane torch!
Old 02-02-2009, 04:23 PM   #40
Great write up Termit. Here is a link to the hilti site which has a great selection of firestopping products. I worked for a commercial construction company for a while and we used these all the time in hospitals. Mostly the fire caulk for penatrations. http://www.us.hilti.com/holus/module...jsp?OID=-18981
ponch37300 is offline   Reply With Quote
Old 02-02-2009, 04:51 PM   #41
Right on. Hilti is a prominent manufacturer of firestopping products. Specseal and 3M are also commonly used and specified.
These are normally not used much in single family residential applications though, since they're for firestopping, not fireblocking. Plus, they're very expensive ($12/tube or more).
Old 02-02-2009, 05:22 PM   #42
gravity always wins
Termite......... you should know that isn't a proven scientific test method.
Agreed. Most firestop products ultimately act as endothermics. During a fire, purely endothermic fire stop products, will remain in the same configuration as they were installed but char over for protection, while intumescent products will expand to fill voids. During a fire, a bundle of wires for example, sealed with an endothermic, such as foam will burn away leaving a hole for smoke and flame to pass through. The sealant has remained intact, but the penetrating item has burned away. The fire seal has ultimately failed. An Intumescent sealant will expand as the wires begin to burn away and close the space, blocking smoke and flame. I realize this may be getting a little too in depth for a DIY site. For what it's worth, 3M and Hilti both offer UL rated firestop systems that use foam.
For construction joints, foam is a good product. For pentrating items, particularly ones that can burn away, an intumescent sealant should be used.
Old 02-02-2009, 05:44 PM   #43
I'm all about doing redneck tests!
Funny thing about intumescent material is that so many tradesmen that install the stuff have no idea how it works or what it does. It is always fun to hit a drop of it with the torch and watch them get all excited.
Old 02-02-2009, 07:43 PM   #44
Ok, stopped and took some pics on my way home today.
This one shows where the electician drilled through the top plate of a wall that will be sheetrocked on both sides. Those holes must be filled with fire foam or intumescent firecaulk.
The second pic shows a wire hole and a pipe in the top plate, both of which must also be sealed. In rated/commercial construction, you'd have to use intumescent firecaulk around the PVC because it will melt in a fire. That isn't necessary in single family residential homes though.
Old 02-02-2009, 07:45 PM   #45
This shows a bottom plate with copper and PVC pipes penetrating it. Also need to fireblock these.
(by the way, the PVC pipe protection is inadequate...a larger plate will be required on both sides)
More On This Topic
Hi, my name is Rachel Perelli Randolf and I'm here with Expert Village on how to talk to you about how to get a great, safe, healthy self tan without getting all those burn marks and so much more. Right now I'm going to talk to you about the certain... Read More »
Hi, this is Jon and in this clip we will be filling our gaps. If we take a look at the inside of our door, we do have some gaps that we need to fill so that we don't get any air coming through there. To fill our gaps we are going to be using a spray... Read More »
Sealing cracks in your foundation or walls will not seal out radon completely. Radon is a radioactive gas that can cause lung cancer. Sealing cracks can, however, increase the effectiveness of a contractor-installed system to lower radon levels in your... Read More »
Hi, this is Kimo Greene, I am here to teach you how to shape a surfboard on behalf of Expert Village. Well, there is two kinds of blanks. The EPS blank is expanded polystyrene. That is what they use when they make epoxy boards. Epoxy is a type of resin... Read More »
I have in my hand a piece of regular foam core which is acid buffered. Which is treated a little bit to ensure that the piece that touches your frame art is not going to be damaged by this product. It has a foam in the middle which gives it a little... Read More »
framing material estimate maydoug Building & Construction 38 06-12-2009 03:32 PM
Double Framing on old Garage? bofusmosby Carpentry 1 11-25-2008 07:36 AM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 11:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 10:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 06:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
