Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 05-08-2012, 09:20 AM   #196
How to fireblock framing
Thank you all!!!!
I am a Newbie and in the process of having my house built but I opted on not having my basement built and using those credits for other items in the house so I will be building my basement myself. I have read thru all 14 pages and at first I was a lil foggy about the whole Fireblocking concept (actually I didnt even know anything about it until I found this website) but it was not until I saw the pics posted by Barlav and hellonoko that it cleared it up for me. THANK YOU!!!!
I will ensure that I adhere to the Fireblocking regs posted here when I begin my Basement framing.
prican_2000 is offline   Reply With Quote
Old 07-16-2012, 04:08 PM   #197
So I came across this thread a little to late I think. My framing is up and now I need some help on how to fire block it.
1. Dow Thermax Sheathing was already on the walls so I left it there and framed next to it. What do I do for horizontal fire-block?
2. Had to frame around waste pipe not sure hot to fire block.
3. Left space for HVAC return air in framing, I cut the thermOpan and found that the return air for the existing connection goes through the floor.
4. Lowered bathroom ceiling do I have to add blocking inbetween each stud right below where the ceiling drywall will be?
Thanks for any help
buildit45 is offline   Reply With Quote
Old 04-08-2013, 03:11 AM   #198
Im going to be finishing my basement soon and not sure if i missed it in the previous threads but my question is;
With the insulation in between the floor joists, do i still need to fire block at the top of the exterior walls or is this sufficient?
How to fireblock framing-dsc01940.jpg   How to fireblock framing-dsc01941.jpg   How to fireblock framing-dsc01942.jpg
ccleme11 is offline   Reply With Quote
Old 04-16-2013, 03:59 PM   #199
Want to Learn
jonhayden's Avatar
This is a great thread and I appreciate all the info. I'm adding a bedroom to my basement and fireblocking the soffit is still confusing me. From what I've read in this thread, it sounds like I only need to fireblock the soffit where it connects to a vertical wall, right? So I just want to confirm I DON'T need to put fireblocking where the joist canals meet the soffit like in the picture I posted. I don't need to put fireblock in the red area below, right? It just seems that if a fire started between the joists, I'd want to stop it from entering the soffit area.
Thanks,
Jon
jonhayden is offline   Reply With Quote
Double Framing on old Garage? bofusmosby Building & Construction 6 04-12-2010 10:08 PM
framing material estimate maydoug Building & Construction 38 06-12-2009 02:32 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 09:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
