Go Back   DIY Chatroom - DIY Home Improvement Forum > DIY Repair > How To Guides
Old 10-19-2009, 10:33 AM   #1
DIY Apprentice
tripflex's Avatar
Default How to find out why your pool pump is not fully priming
Okay guys, so after all my adventures with my new house and pool, i figured i would share some great information that i figured out over trial and error.
Basically after replacing my pool pump with a brand new $400 one, i still want not getting my pool pump to fully prime!
BTW just in case anybody doesn't know, when your pool pump is running, if you look down into the basket on the pump you should just see water, you shouldn't see swirls or the water flowing in from the pipe, it should look like the basket area is just full of water
The reason i post that above is because when i figure bought my house, i didn't know that! So i thought my pump was running correctly until i had a friend come over that works for a pool company.
Anyways, after he came over i still could not get my pump to fully "prime" or work correctly...somehow there was air getting into my pump.
Turns out, the way i figured it out was such a simple solutions i wish i would have tried it earlier. (i figured this out on accident!)
I was working on cutting out my chlorinator to put in a new valve and i was holding my hose with it running away from my body. I look over to the right and the hose just happens to be spraying where my intake pipe is, i look at the pump and it is working perfectly!
I was amazed! So basically if you cannot get it to fully prime/work, take a hose, spray it around the intake pipe, pump lid, or any other parts or valves before the pump, if the pump starts working correctly you know that's where the air is getting in!
Just thought i would share that because of how amazed i was when i figured it out, and i was working on another problem when i figured out the pump one!
"How else am i supposed to build my tool collection and owe home depot lots of money? That's why I DIY"
2,200 SQ ft 3/2 Lake house with in-ground pool: http://picasaweb.google.com/tripflex
Help us help you by posting pictures with your question!!
tripflex is offline   Reply With Quote
More On This Topic
Troubleshoot Pool Cleaner
Troubleshoot Pool Cleaner by Expert Village
Care and maintenance of the Wanda the Whale above ground pool cleaner, making sure the pumping filter is working, the turbine spinning and the hoses are in good condition in this free maintenance video. Read More »
Hi this is Francisco Cales in Tampa, Florida with Pool Inspectors on behalf of Expert Village. Our theme for today is basic pool maintenance. The next steps we need to do is go ahead and clean the basket inside the pump. One of our main things with pool... Read More »
Hi, my name is Nathan McCullough on behalf of Expert Village. In these clips we're going to talk about some of the possible problems with your windshield washer system and some hints and tips to get better performance out of it. In this clip we're going... Read More »
Water gardens can add beauty to any landscape. Once you install your water garden pool, it's time to add a water garden pump. This pump will add visual interest with the movement of the water, as well as circulate water to avoid stagnant water, which... Read More »
Jacuzzi Pump Maintenance
Jacuzzi Pump Maintenance by Expert Village
Hi, this is Francisco Calas from Tampa, FL with Pool Inspectors on behalf of Pool Inspectors of Expert Village. Our theme today is basic spa maintenance. Next step we need to do is go ahead and clean the basket inside the pump. One of our main things... Read More »
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 08:10 PM
Replacing cord on a 1.5 hp above ground pool pump LeeAmes Electrical 24 04-20-2009 03:45 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 08:09 PM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 10:41 PM
Just to confirm, no GFCI needed for hard wired pool pump..right?? Al the Diy guy Electrical 6 02-10-2008 02:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
