How To Create A Skip Trowel Texture (Photos/Video) - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Like Tree1Likes
  • 1 Post By Sir MixAlot
Old 03-13-2014, 08:15 AM   #1
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
How to create a skip trowel texture (Photos/Video)
I get a lot of questions about Skip Trowel Texture.
So, I put together this How to article on skip towel texturing.
These photos below are examples of a few of the many variations of skip trowel texture.
When I say “variations” there are several factors that determine how the skip texture will look. One of the factors is the “surface” that is going to be textured.
Skip trowel texture can be applied in a light, medium or even a heavy consistency, depending on whether you’re going for an old world, modern or custom texture.
New drywall, primed drywall, previously painted surfaces, amount of sand added and how thick or thin the texture material is mixed are just a few of the factors determining how this hand texture will pull when applied.
Skip trowel texture can add a beautiful Mediterranean or Spanish flair to any rooms ceilings or walls
Skip trowel is great texture for help hiding imperfections on a ceiling after removing a popcorn ceiling, or a ceiling or wall that has a lot of cosmetic issues or a area that has been repaired and was previously textured with skip trowel.
Texture matching is a challenge that really takes years to perfect
Step 1) Remove anything you can in the room that you will be applying the skip trowel in.
Step 2) Cover and protect any flooring, furniture or anything else that you don't want any texture on. Use a drop cloth, heavy mil plastic or rosin paper to cover the floor and light plastic to cover everything else.
Step 3) Mix all purpose joint compound with sand and water in a 5 gallon bucket. Start by mixing half a five gallon bucket of joint compound with about two to four cups of water and three or four cups of clean sand. Mix in all of this together until it reaches a pancake batter consistency of thickness. For a thicker texture, add less water. Let mix sit for 15 minutes. Remix and add water if needed to get desired consistency. Maybe practice on a scrap piece of drywall to try and achieve the desired skip trowel texture you're looking for.
Step 4) Scoop some of the skip trowel mix out of the bucket onto either a hawk or drywall mud pan. Using a trowel or mud knife and put about an inch of your mix on the whole long working edge of the trowel or knife. Now start by finding a inconspicuous area of the wall or ceiling in the room you will be texturing (if possible). Lightly pull your trowel from the corner of the ceiling or the bottom of wall pulling towards the top, holding the trowel at a 15 degree angle and making short subtle skipping motions.
Step 5) After you have applied the texture to about a 4'x4' area, drop back and lightly go over that area with a clean wet trowel. This will smooth out any blobs or trowel chatters that might have been left behind.
Step 6) Allow at least 24 hours for the skip trowel to dry completely before you prime and paint. Using a 3/4" nap apply your favorite top grade primer and two coats of a quality paint to your masterpiece. Pick up all of drop cloths and plastic.
Step 7) Kick back and admire your beautiful new ceiling that you did all by yourself. Enjoy!
Source: http://peckdrywall.com/apply-skip-trowel-texture/
Sir MixAlot is offline   Reply With Quote
The Following 5 Users Say Thank You to Sir MixAlot For This Useful Post:
bbo (03-17-2014), Daugela (01-27-2016), r0ckstarr (03-13-2014), rossfingal (03-14-2014), TheEplumber (03-15-2014)
Old 10-15-2016, 04:05 PM   #2
Rewards Points: 918
Re: How to create a skip trowel texture (Photos/Video)
I just wanted to add a couple more How to Skip Trowel videos to this guide just in case there's any DIY members out there that want to attempt doing a skip trowel texture on one of their projects.
kwikfishron likes this.
Tags
ceilings , drywall , mix , skip trowel texture , video
is this a skip trowel texture? (picture) i need to recreate it langless28 Drywall & Plaster 2 12-22-2012 09:24 PM
skip trowel ceiling letty1 Drywall & Plaster 3 07-26-2012 09:55 AM
Skip Trowel Texture Briyon Drywall & Plaster 1 03-23-2011 10:20 AM
How to create this texture yxw168 Painting 2 11-11-2010 04:58 PM
Smoothing out skip troweled wall texture wem Remodeling 2 03-03-2008 11:57 AM
