How To Build A Laminate Countertop - How To Guides - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 04-13-2013, 10:00 PM   #16
r0ckstarr's Avatar
Rewards Points: 2,052
I called up a local lumber store today and asked if they had AC or BC plywood. They said they had both. I went down and couldn't find the AC. I only found the BC. When I asked about the AC, they pointed me to this.
Any idea about this? I know nothing about it, which is why I am asking. The BC plywood was listed as BC plywood. This wasn't listed as AC plywood. Maybe it's the fact that most everything that comes from China isn't the greatest, but I figured I would see what I could find out about it first.
Looking it up online, I found that it's for interior use, imported white birch, from China. Would this be the same as the imported birch you were referring to in a previous post?
r0ckstarr is offline   Reply With Quote
Old 04-13-2013, 10:29 PM   #17
Ole Wood Worker
BigJim's Avatar
Rewards Points: 380
Was the import birch cheaper? That is a little high for a counter top. Check the import birch and see if the veneer is super thin, if it is it is paint grade and should be a cheaper grade. AC plywood is A grade on one side and C grade on the other, BC is B one side C the other. The A grade side should be free of knots and holes, the C side will have holes were knots fell out and such.
BC plywood, the B side will have football shaped plugs but no holes and will make a good base for a counter top. Which ever you buy be sure to check to see if the plywood is delaminating. A lot of Home Depot and some Lowes plywood is bad about that.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
r0ckstarr (04-13-2013)
Old 04-13-2013, 10:33 PM   #18
r0ckstarr's Avatar
No, the BC plywood was about $16.00 cheaper than what's in the picture. This wasn't at a Home Depot or a Lowes. It was at a place called McCoys.
https://www.mccoys.com/
Also, I made a mistake. My picture shows Red Oak. Under the picture I posted, I said it was White Birch. Sorry, I got the two mixed up.
Old 04-13-2013, 10:39 PM   #19
Ole Wood Worker
BigJim's Avatar
Rewards Points: 380
I would go with the BC.
Jim
Old 04-13-2013, 10:42 PM   #20
r0ckstarr's Avatar
Thanks.
Old 04-15-2013, 07:03 PM   #21
r0ckstarr's Avatar
The stuff above is paint grade. I went to another lumber yard today and got some real nice AC fir at $42.00 a sheet. They even let me go into the warehouse and pick out the pieces I wanted. Will update as I make progress. Thanks again for the help BigJim.
The Following User Says Thank You to r0ckstarr For This Useful Post:
BigJim (04-15-2013)
Old 05-10-2013, 09:29 PM   #22
r0ckstarr's Avatar
I'll make another thread showing the full progress soon. I don't want to hijack this one. Here's the nearly finished results.
Thank you for this thread, and for all of your help, BigJim. I truly appreciate it.
The laminate is Canyon Black by Wilsonart.
This is how they really look.
When I learn more about electricity, I plan to swap the outlets out with grey outlets. For now, I put the grey trim on.
Ignore the pan on the bar. I moved it off of the stove when I took a picture of the stove, then forgot that I put it on the bar when I took this picture.
Next up is to get matching knobs and hinges, paint the cabinets, finish the bar top, and the floor. (Not exactly in that order.) I have the bar top built, but decided not to laminate it and do something else.
Old 05-10-2013, 09:52 PM   #23
Ole Wood Worker
BigJim's Avatar
Rewards Points: 380
Buddy, you did a fantastic job, looks great.
Jim
r0ckstarr (05-10-2013)
Old 05-10-2013, 09:54 PM   #24
r0ckstarr's Avatar
I couldn't have done it without your help. If not for this thread, I wouldn't have thought to ask some of the questions I did, and most likely would have used the wrong materials, or not completed it right the first time. Thank you!
BigJim (06-08-2013)
Old 05-25-2014, 08:15 AM   #25
Man, you did a great job on that joker..!
b75nweav is offline   Reply With Quote
The Following User Says Thank You to b75nweav For This Useful Post:
r0ckstarr (05-26-2014)
Old 02-21-2015, 11:27 PM   #26
Rewards Points: 131
I realize this is an old thread but I thought it might be worth posting here.
I am planning to make my own laminate countertop. How do I deal with 45* angles? I don't have my exact measurements yet. But, I have a u-shaped counter that will be longer than 8 feet and the peninsula end wil be wider than 4 feet. So, I will have to match up cut pieces of laminate/decking.
wwkayaker is offline   Reply With Quote
Old 02-21-2015, 11:37 PM   #27
Ole Wood Worker
BigJim's Avatar
Rewards Points: 380
You can get HPL 5 feet wide X 12 feet long. If you are using a random pattern or solid color you can butt the joints instead of 45ing them.
Jim
Old 02-22-2015, 09:34 PM   #28
Rewards Points: 131
Thanks. I am using a random pattern so I will butt the joints.
The Following User Says Thank You to wwkayaker For This Useful Post:
BigJim (02-22-2015)
Old 02-22-2015, 11:56 PM   #29
Ole Wood Worker
BigJim's Avatar
Rewards Points: 380
When you pick up your HPL ask to buy a matching tube of seam filler, sometimes it can come in handy.
Jim
Old 03-21-2015, 05:17 PM   #30
Rewards Points: 131
I am going to do butt joints but how is the best way to connect the tops. What I am thinking of doing is making my peninsula as one countertop. Then the run under the window as a second counter. Initially, I thought of using a piece of wood under the seam to connect the two counters. Today, I have been reading about countertop bolts. Would it be better to use bolts to connect the two pieces together?
Tile on Laminate onthebrinck Remodeling 2 10-26-2012 10:26 AM
Laminate countertop mitered joint question lemmy999 General DIY Discussions 5 10-18-2011 04:54 PM
Glueing Countertop Laminate on Door Sonya_ Kitchen & Bath Remodeling 16 10-03-2011 11:55 AM
butt joint pre-fab laminate countertop mrennolds Kitchen & Bath Remodeling 3 07-04-2010 11:34 PM
laminate countertop ? jdixon General DIY Discussions 9 03-19-2008 09:15 PM
