Drywall Finishing- How To Get A Flat Butt Joint With Fiberglass Mesh Tape - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > How To Guides
Old 07-14-2015, 07:10 AM   #1
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 724
Drywall finishing- How to get a flat butt joint with fiberglass mesh tape
In this how to drywall finishing video I'll show you how I finish a butt joint on a new drywall ceiling that I installed.
Butt joints seem to be one of the hardest things to get flat when mudding drywall seams. Whether you're contractor, tradesmen, handymen, or an HGTV DIY'er, with these easy tips and tricks you should be able to get a flat butt joint on your drywall finishing or drywall repair projects. I use the same technique for walls and ceilings, new drywall, ceiling repairs and wall repairs.
Good luck on your drywall project and let me know if you have any questions.
-Paul
PeckDrywallandPainting.com Twitter Facebook Linked in Google+ Youtube
Checkout some of my How to videos->How to Secrets from a Drywall Finisher
Sir MixAlot is offline   Reply With Quote
Old 07-14-2015, 07:15 AM   #2
Rewards Points: 9,816
Why not just use paper and not have to deal with it?
Old 07-14-2015, 08:07 AM   #3
Rewards Points: 724
Deal with what?
I think a Do it yourselfer is more apt to get a flat butt joint with fiber tape then paper tape (ie: not having to bed the tape. That's usually what causes the hump right off the get go).
-Paul
The Following User Says Thank You to Sir MixAlot For This Useful Post:
jcrizzy (09-02-2015)
Old 03-16-2016, 05:09 PM   #4
bradleyshome's Avatar
Rewards Points: 114
Re: Drywall finishing- How to get a flat butt joint with fiberglass mesh tape
Some people are too lazy to do the job right haha Looks good Sir MixAlot
bradleyshome is offline   Reply With Quote
The Following User Says Thank You to bradleyshome For This Useful Post:
Sir MixAlot (03-20-2016)
Old 03-20-2016, 02:58 PM   #5
First Home
Rewards Points: 316
Thats a ton of mud, almost the entire ceiling.
I got the impression you have have switched muds after first coat? Any reason or preference? I usually use the powder and mix myself, havent had good luck so far with paper tape
KevinEF7 is offline   Reply With Quote
Old 03-20-2016, 10:09 PM   #6
Rewards Points: 112
Ive recently starting doing drywall in my basement, I use the self adhesive mesh tape. At first it was hard to get the butt joints to not be visible but i learned how to make it go away by using a technique like yours. Thanks for the helpful video!
Chrisathome is offline   Reply With Quote
The Following User Says Thank You to Chrisathome For This Useful Post:
Sir MixAlot (03-21-2016)
Old 03-21-2016, 05:25 PM   #7
Rewards Points: 724
LOL... I Like my butt joints flat!
Yes, I always use quickset joint compound (powder form) for the first coat of mud over fiberglass mesh tape (per manufacture instructions). Then, for the next two coats I used USG all purpose joint compound. The AP must skims smoother and sans much easier. That's why I like to use it for the final coats.
-Paul
Old 03-21-2016, 08:31 PM   #8
Gymschu's Avatar
Rewards Points: 4,710
Sir Mixalot, where have you been? Must be pretty busy down there in the Sunshine State!
Giving us your general location helps us better help you!
Gymschu is online now   Reply With Quote
The Following User Says Thank You to Gymschu For This Useful Post:
Old 03-21-2016, 09:07 PM   #9
Rewards Points: 724
Yes I have. Been on a large custom condo renovation for the last 5 months. Been doing lot's of interesting stuff from curved ceilings to my favorite, inset baseboards using reveal beads and cement board.
-Paul
Gymschu (03-22-2016)
Old 03-27-2016, 08:43 PM   #10
Rewards Points: 4,746
OK that's nice, but to be fair it's not possible to get flat butt joints with any standard method. The only way to get a flat butt joint is to do back blocking. It's always seemed to me that most DIYers use mesh tape for the convenience, which it seems to me is negated by using a setting compound. But I suppose if you hate paper tape that much, it's probably worth it to a DIYer to use setting compound with mesh. I think FibaFuse would be the best of both worlds of course.
jeffnc is offline   Reply With Quote
Old 03-28-2016, 08:06 AM   #11
Rewards Points: 724
Flat as in no hump...
To be fair, even using back blocking it's not "flat".
You still have the build up of tape and joint compound on top of the drywall seams. It's no different than attaching to a framing member. Unless you also manually taper the edges of the two butts.
In my opinion it is much easier for a DIYer to get an "acceptable" butt joint using fiberglass mesh tape than it would bedding and applying paper tape.
-Paul
Old 03-28-2016, 08:21 AM   #12
Yes, what we're talking about is "acceptable" more so with one technique than another. There is always a "hump" with standard butt seams, but if you keep it low and spread it out wide, it can be virtually invisible.
The reason you can literally eliminate the hump with back blocking is because it's not done over a stud - you're receding the drywall backward slightly so it's concave, and the buildup of tape and compound does not make it convex, that's why it's different than attaching to a framing member. With a standard seam all you can do is reduce the hump and spread it out so it's difficult to see.
Here's a commercially made one, you can also make your own in different ways.
Drywall finishing- How to get a flat butt joint with fiberglass mesh tape-buttruler4.jpg
Old 03-28-2016, 08:30 AM   #13
That's true, but I still think FibaFuse would be better still.
Using a commercially made back blocker would have the following advantages for a DIYer:
- Usually don't have to cut the drywall to fit on a stud - just install it wherever the drywall ends inside a stud bay. Saves time by eliminating a lot of cuts (the back blocker takes room so sometimes you'll still have to cut.)
- No hump to try to smooth out wide since it turns butt joints into tapered joints.
- No concerns about having just a sliver of a stud space to screw the drywall to, and having the screws crush the edge of the drywall.
- They can use paper tape if they want to with no worry about the buildup creating a big hump.
The downside is cost, but they could make their own version for less.
There are occasionally critical areas where a convex butt seam is not acceptable, no matter how skillfully tapered. For example if some sort of desktop, shelf or counter needed to go against a wall and be perfectly flat against the wall. A back blocker is the only way to get a seam truly flat.
Old 03-28-2016, 09:14 AM   #14
Rewards Points: 724
That's what I said. Not very DIY though.
Which is why I posted this video on a DIY site.
-Paul
Old 03-28-2016, 09:55 AM   #15
It's pretty easy to make DIY back blockers. It's shown at the bottom of Step 2 in this series.
http://www.diyadvice.com/diy/drywall...g/butt-joints/
That's the only way to get a flat butt joint. As I mentioned above, back blocking has a lot of benefits for the DIYer, and if you make your own, even the cost factor isn't an issue. IMO, homemade back blocking, along with FibaFuse and premixed joint compound, is the easiest way for a DIYer to get good results. Stronger then mesh tape, no bubbling or embedding of paper tape, no powder to mix up (and then have to clean the mixer and bucket), and a perfectly flat joint with no fuss.
Those *#@& air bubbles under drywall tape spaceman spif Drywall & Plaster 12 03-02-2012 05:22 PM
Drywall : Fiberglass tape or paper ??? shopvike Drywall & Plaster 10 10-07-2011 04:58 PM
drywall tape coming off jlajla24 Drywall & Plaster 5 12-04-2008 09:27 PM
Drywall finishing JimmieC Building & Construction 4 07-07-2006 05:26 AM
Mesh drywall tape...2 questions scarrell Building & Construction 4 03-27-2006 10:51 PM
