DIY Dowel Tool Storage - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > How To Guides
Old 03-15-2017, 10:11 PM   #1
Rewards Points: 2,030
I'm sure as DIY'ers you have considered making garage tool storage neater and the dowel rod idea certainly isn't unique by any stretch. So if you are new to DIY and you go the the store to buy wooden dowel rod to make this fine project you may select 3/8", 7/16" or possibly 1/2" diameter rod as the appropriate size. OK, I got a new drill bit set for Christmas with all those sizes and I'm ready to get-er done.
So you get home with these dowels selected, choose the appropriate bit, bore a hole at a gusstimated angle in that fine piece of lumber rather than a scrap piece, and low and behold those stupid dowels are loosie as a goose. No amount of glue will work and make a satisfactory fit and even a non-seasoned wood worker would know that. Then I discover those dowels aren't even round like they look either.
So don't despair, all isn't lost if you have a spade bit of that size selected for the holes. No it probably wasn't in the Christmas gift set.
I have a good set of spades and a not so good set. I choose the not so good to re-size to fit the under size dowels that have shrunk in diameter because the dowel rods were machined when they were green and have dried out smaller and of round. For this project let's not pay much attention to Out OF Round, OK.
Now to the trusty bench grinder to make a spade bit bore a smaller hole. Yep, a few thousandths off each side, it's possible and a common practice. I've read it can be done with a file but I haven't tried that being my grinder is handy.
Old 03-15-2017, 10:28 PM   #2
jlhaslip's Avatar
Rewards Points: 2,864
Re: DIY Dowel Tool Storage
What I have done to tighten those sloppy dowels is to drive a screw into the dowel from the back side.
Predrill it undersize and the screw will wedge out the dowel to fit.
Glued, of course, as well.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Most Helpful Non-Standard Tool dougp23 Tools 30 10-10-2016 06:05 PM
Cordless Tool Brands & Upcoming Deals BHR Tools 17 11-28-2015 06:52 PM
Need a tool to remove a sink faucet 1-1/2" nut mystic_cobra Plumbing 6 08-26-2015 07:20 AM
connecting 2" water line poly pipe with tool Renaldo7 General DIY Discussions 17 05-20-2015 08:47 PM
Tool storage cellophane Tools 19 01-05-2011 03:51 PM
