With Incandescents being "outlawed" many people will need to buy & install CFL's
Seems many people are dissappointed by the color/light output of CFLs
This thread is a discussion, explanation of the color/lighting available
1st CFL's come in different wattages - & list the equivelent incandescent wattage
Normal wattages are - these vary slightly by Mfg:
CFL
9w .........= 40w equiv
12/13w....= 60w equiv
14/15w....= 75w equiv
22/23w....= 100w equiv
65w........= 500w equiv (floodlight)
There are smaller wattages, but they tend to be more expensive
CFLs DO contain Mercury - same as every flourescent light in almost every workplace for decades
The overall mercury put into the environment is LESS due to the fact they use less energy
That means less energy needs to be produced, as a result less mercury is created in creation of electricity
http://www.energystar.gov/index.cfm?...r_cfls_mercury
Incandescents produce only 10% light & the rest of the energy used is heat
CFL's produce the opposite, only 10% heat
If you have a recessed can or other fixture that blinks on/off with an incandescent then try a CFL
Recessed cans have a thermal sensor, if it gets too hot it shuts the light off
CFL's come in many different types, the curly bulbs are the most widely known
But they also come in a reg glass bulb enclosing the CFL within
These are great for the lamps where the shade is "attached" to the bulb
Yes - this is a CFL bulb too:
CFL's come in different light "colors" - Kelvin rating = K
Please note the K ratings will change by Mfg & Mfg can change these at times
Also note that many bulbs will NOT list the K rating on the bulb - only the pkg
Lots of times I will use a marker & write the date of installation on the bulb base
In some cases I also write the K color on the base
Normal green pak from HD Nvision Mfg = soft white = 2700K
Red package from HD Nvision Mfg = Bright white = (4500k ? - guessing)
Blue pak from HD Nvision Mfg = Day light = 5500K
Blue pak from Lowes Bright Effects Mfg = Day light = 6500k
That's it for now
-Dave
