Ceiling Fan - How To Guides - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > DIY Forum > How To Guides
Old 08-31-2014, 03:13 PM   #1
Nelmarti217's Avatar
Ceiling Fan
What would be the safest way to install a small four bladed ceiling fan into a concrete ceiling, over a bed?
Nelmarti217 is offline   Reply With Quote
Old 08-31-2014, 06:43 PM   #2
Ceiling Fan
Are you asking what to use to attach to the concrete?
I would probably do it with Tapcon screws.. Those things are amazing..
PaulBob is offline   Reply With Quote
Old 08-31-2014, 08:07 PM   #3
Ceiling Fan
Yes, but I want to make sure that the tapcon screws wont fail along the way with the vibration of the fan. Since the fan will be over my bed, It's going to hurt a lot if it falls on me. Anything else more secure that I can use or this it?
Old 08-31-2014, 09:16 PM   #4
Ceiling Fan
I have never seen one of those screws fail...
Beyond those, you could also use a concrete wedge anchor..
If you're worried about it falling, than the trick is to install a safety catch... that too could be based on Tapcon screws.. You simply install one screw so that it is not bearing any of the load.. That screw has a small chain that attaches to the fan frame.. if the load bearing screws were to ever fail (ya right!), that last non-bearing screw would catch the fan.. You might have to change your shorts when the fan drops 6 or 8 inches and wakes you up with all the clatter, but it wouldn't fall.
Tapcon screws are extremely reliable.. I've never seen one go bad and I used to work in an industrial environment where the machinery vibrated intentionally.. The vibrations were so intense you could feel it when you got out of your vehicle in the parking lot outside the building.
If you put four 1/4 inch tapcon screws in, you could probably remove one of the blades and the fan would shake itself to pieces before the screws came loose.
Old 08-31-2014, 09:22 PM   #5
Ceiling Fan
Thanks, I appreciate your help. The safety chain idea is great. Never thought of that. I guess I will go with tapcon. Incidently, don't worry, I have a few more pairs of shorts.
Ceiling Joist Size russ_mc Building & Construction 7 02-24-2012 05:06 PM
Popcorn ceiling with asbestos - options? 30Five Drywall & Plaster 6 02-21-2012 10:27 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Level 5 finish expectations? Cracked ceiling.....input needed please! HeatherJ Drywall & Plaster 6 01-14-2011 06:04 PM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 09:23 PM
