Windmill Brake. - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 11-26-2012, 05:20 AM   #1
Items wanted: Time
Rewards Points: 150
Windmill brake.
I am building a windmill to aerate my pond. I have a blade from a thousand ton cooling tower, I took a air pump from an old school building and will link them together with a set of pulleys and a belt. My problem is when we get gusts of wind in 50's I don't to have to find pieces of my windmill in the neighbors yard. So I need a brake on it to prevent from spinning out of control. I have looked around and haven't really come up with anything.
NiNe O is offline   Reply With Quote
Old 11-26-2012, 06:52 AM   #2
DIY staff
Rewards Points: 7,174
I know nothing about this other than the name of the part you need--centrifugal brake - Google Search
Good luck----
NiNe O (11-26-2012)
Old 11-26-2012, 08:00 AM   #3
Rewards Points: 252
You could try a Furling system (I had to look up the name, so don't take me as an expert). The turbine is essentially mounted on a hinge with a spring and when the wind blows too hard the turbine rotates out of the wind and slows down.
shazapple is offline   Reply With Quote
The Following User Says Thank You to shazapple For This Useful Post:
NiNe O (11-26-2012)
Old 05-04-2014, 06:04 PM   #4
Rewards Points: 332
Send a message via Yahoo to curtd
What a cool project. Some pics after you build it maybe ? Oh'Mike's idea reminded me of my mini bike. May be you can use a clutch. It works on centrifigual force
curtd is offline   Reply With Quote
Old 05-04-2014, 06:29 PM   #5
Rewards Points: 13,712
Check out the Mother Earth News website.
There all about being off the grid.
Old 08-09-2014, 11:32 AM   #6
Oso954's Avatar
Rewards Points: 1,110
I would suggest going to Fieldlines.com which is the discussion forum for Otherpower.com. They have some real wind experts there.
I hope you have a good blade set. Some cooling tower blades make a decent windmill. Others do not.
Oso954 is offline   Reply With Quote
Old 08-10-2014, 12:11 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Before you go "off-grid" VOTE in the Project of the Month contest here at DIY Chatroom.
XXX
Old 08-10-2014, 08:09 PM   #8
+1 on the furling system.. By far the best way to go...
PaulBob is offline   Reply With Quote
Old 11-13-2014, 07:02 AM   #9
Rewards Points: 163
Yeah, the furling system sounds about the easiest. I don't know if you could rig up a brake that would last long to keep that slowed down.
The only other way would be to get rid of the lift created by the blades, I think that's typically done by rotating the blades on big units, but I doubt you have that option off a cooling tower fan.
How about a governor system that would slide out on the blades as the centripetal force increases from the increased speed. As they slide out it would cover up the blade and change the shape of the airfoil to reduce lift, thereby slowing down the rotation?
Sounds good in theory, but I have no idea how you could accomplish that at home!
52Caddy is offline   Reply With Quote
Warped Brake Rotors - The Cause? DrHicks Automotive Repairs 14 01-20-2013 07:08 PM
Need aluminum/trim brake Pittsville Building & Construction 26 10-21-2011 05:53 PM
Trailer/truck brake controller problem govman Automotive Repairs 6 10-30-2010 02:46 PM
brake pedal travel & force Yoyizit Automotive Repairs 3 09-07-2010 08:00 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 07:48 AM
