What Works For Me - Green Home Improvement - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 01-14-2009, 10:39 PM   #16
Rewards Points: 336
That makes sense, it would be easier than removing a kitchen cabinet. Do you drill a few holes starting in the lower part of the corner to the top and start filling with foam from the lowest one?
It's weird, the two corners on the south side of the house have the water problem, but the other two on the north side, in the kitchen and living room, are dry.
gma2rjc is online now   Reply With Quote
Old 01-15-2009, 11:25 AM   #17
I'm not good with clip art and photos. If someone could attach a cross section of a 2x4 outside wall corners and an inside wall butting an outer wall it would help. You may have a vapour issue as well as cold.
In my case I discovered the open pocket from the attic above the garage. The temp scan just confirmed my concerns. I am debating filling the corner as you suggest with holes, but I may also peel the drywall back about 8' to a doorway and put Dow foam boards, tyvek wrap??? and then recover it with fresh drywall.
Although my corner pocket would improve with drilling and foaming the balance of the wall is still an issue and I have a door and cantalevered 2x3' pantry jutting into the garage on the same wall further down which are both insulating projects as well.
Chemist1961 is offline   Reply With Quote
Old 03-19-2009, 12:24 PM   #18
Rewards Points: 336
I got my gas bill yesterday. My ccf usage dropped 19% since last year after making just a few improvements:
-added a draft blocker to the dryer duct & insulated part of the duct
-sealed the attic, installed baffles (haven't added blow-in insulation yet)
-sealed accessible seams on heat ducts (not 100% finished with that)
-insulated 4 corners of the house (from the exterior)
-vented bathroom fan to outside, added draft blocker, insulated duct
-sprayfoamed accessible rim joists & some other gaps
-sealed gap between floor & exterior walls in one room
-added foam gaskets to outlets on all exterior walls
-replaced a few windows
-insulated access panel to attic and replaced gasket
-complained a little
I'm really happy with the 19% drop and after adding the insulation to the attic this spring, hopefully the gas bill will be even lower next winter.
Old 03-24-2009, 11:46 PM   #19
DIY Junkie!!
Rewards Points: 180
Originally Posted by gma2rjc View Post
I got my gas bill yesterday. My ccf usage dropped 19% since last year after making just a few improvements.....
Just wanted to say thanks, this is a way-cool thread. I'll have all the basement ceiling out of an almost 100 year old house this summer, putting in hydronic radiant heating, and had I not read this I would likely have left that sill plate and rim joist alone....now I will definitely pay more attention to that area before I cover it back up again!
Keep it up, please....
Dugly
YerDugliness is offline   Reply With Quote
New Subpanel Almost works soccio97 Electrical 19 09-04-2008 08:12 AM
Only 1 of 2 Heating Zones Works KMPPROB HVAC 3 01-06-2008 02:13 PM
Blower fan works , but no heat or Ac. will1976 HVAC 1 10-31-2007 12:24 PM
Gas oven does not work; pilot light on, stovetop works fine kathleentsy Appliances 1 05-22-2007 06:05 PM
how to hold up my roof while the joiner works on it plotone Roofing/Siding 2 12-26-2006 10:00 PM
