Use Of Schedule 40 Galvanized Pipe As A Pole - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 07-14-2014, 09:15 PM   #1
Post
Use of schedule 40 galvanized pipe as a pole
I'm trying to mount a solar panel rack with 2 panels using a 10' and 5' length of sched-40 2" galv iron pipe. It will be 2' in-ground (concrete), supported every 24" with strapping to one leg of wood tower and only the top 4.5' is unbraced...
Is this kind of pipe OK for this? It seems sturdy but I'm not sure if it is OK in cold weather(?) and whether it will be susceptible to bending with a wind load. Finding a similar steel pole has been challenging.
Anybody have advice?
Mulligan99 is offline   Reply With Quote
Old 07-15-2014, 09:11 AM   #2
47_47's Avatar
Rewards Points: 62
My one satellite dish (~2' ellipse) was mounted on a 10') 2" sch 40 pipe. It was buried 4' down (frost line) with concrete.
47_47 is offline   Reply With Quote
Tags
diy advice , solar installation , structural post
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
galvanized pipe to pvc markharmon Plumbing 6 05-04-2013 10:55 AM
Joining galvanized pipe to PVC jtitus Plumbing 6 12-31-2011 07:16 PM
is it possible to use a compression shut off on Galvanized 1/2" pipe? Limit54 Plumbing 8 04-11-2010 09:24 PM
burying galvanized steel pipe amakarevic Plumbing 9 08-19-2008 10:37 AM
