Steam Engines - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 03-14-2011, 04:53 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 72
Steam engines
I was thinking, the way a typical steam engine works, there is exhaust steam. This is still very hot. Would it work to just feed that steam into another steam engine, and keep going for a bit, maybe 3, even 10 engines in serries? I imagine eventually the steam is no longer hot enough, but could'nt you just pass it through multiple engines to try to extract every bit of heat out of it? these separate engines would have to work inderpendantly, but if you are doing something such as generating electricity, then it can always be combined after.
all this reading on the Japan nuclear issues and steam engines (which is basically what is generating the electricity in a nuke plant) got me thinking. though from my understanding of nuke plants the steam is just recycled back after being cooled. Is this more efficient? The cooling process is just outputting that heat into the air though.
I can't be the first person to think of this so my gut feeling is that it would not work, but why?
Old 03-14-2011, 04:58 PM   #2
Civil Engineer
Rewards Points: 4,572
This is a very old idea, and is very commonly used in steam turbine generating electric plants. However, the "used" steam is normally utilized to generate hot water or low pressure steam for heating, rather than being used in a second steam turbine, because the efficiency of the second turbine is going to be very low due to fundamental principles of thermodynamics (see Carnot equation for a full explanation). As for steam engines, which you asked about, they are rarely used anymore, except for a few curiosity locomotives and perhaps in some third world countries, they have been replaced almost entirely by gasoline and diesel engines, and turbines as I mentioned above.
Daniel Holzman is online now   Reply With Quote
Old 03-14-2011, 05:04 PM   #3
Learning by Doing
Leah Frances's Avatar
In this house we obey the laws of thermodynamics - Homer Simpson.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-16-2011, 10:29 PM   #4
Rewards Points: 163
Love the Homer quote!
That's what is done with superheated steam. Heated above the saturation temperature/pressure and it's used more than once, running a turbine and then exhausted and used in another turbine. I'm pretty sure there's not much energy left in the steam when they're done using it. Actually that is what they accomplish through a turbine, each subsequent blade/stage is larger since the steam has lost energy across the first set.
I don't think any nuke plants use superheated steam. Conventional plants use the combustion exhaust to heat the steam above the saturation temperature. In a pressurized water reactor, you get the primary water hot and then generate steam in a steam generator, but you don't have any way to heat it more. Same thing goes for a boiling water reactor.
At least that's what the Navy's nuke program taught me!
52Caddy is offline   Reply With Quote
Old 03-17-2011, 02:43 PM   #5
Rewards Points: 127
What you describe is a compund steam engine. In the golden age of rail, steam locomotives used compund cylinders for this reason. If you look carefully at some of the period photos, you can see that there are actually two cylinders with pushrod arrangements for the drivers (drive wheels); high and low pressure cylinders. the 4-8-8-2 cab forwards and the 4-8-8-4 Big Boy (7000 hp steam locomotive) run by the Union Pacific are great examples.
ptarmigan61 is offline   Reply With Quote
The Following User Says Thank You to ptarmigan61 For This Useful Post:
joasis (04-25-2011)
Old 03-17-2011, 04:04 PM   #6
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
As others have explained, with a turbine, there are typically multiple stages within what you see as one turbine to take advantage of the remaining force of the steam as it passes through the turbine. If they could toss on another stage and improve horsepower, they would.
this is a crude drawing but it shows exactly what you are talking about doing:
http://www.ephf.ca/electricity/turbine-generator/
Old 04-24-2011, 12:39 PM   #7
Steam engines are very efficient engines are they not? I always loved the idea of using steam to power some kind of generator... isn't the true waste of energy simply creating the steam?
dberladyn is offline   Reply With Quote
Old 04-24-2011, 06:49 PM   #8
Civil Engineer
Steam engines which use pistons (this is NOT a steam turbine) are not very efficient. They lose efficiency in two distinct thermodynamic ways. The first loss occurs because the heating of the water using either wood (the old engines) or coal at best extracts about 50% of the theoretical heat in the wood or coal. Additional losses occur due to Carnot inefficiencies in the engine itself. For a theoretical Carnot engine, the maximum theoretical efficiency is E = (T1 - T2)/T1 where E is the efficiency in percent, T1 is the gas temperature at the inlet, T2 is the gas temperature at the outlet. All temperatures must be in degrees Rankine (Fahrenheit) or Kelvin (Centigrade).
The problem with steam engines is that the steam must be exhausted at no less than 212 degrees F (672 degrees Rankine), else it condenses to water and you cannot exhaust it. Typically, you can't heat the steam much past about 500 degrees F (960 degrees R), so this creates a maximum theoretical efficiency of (960 - 672)/960 = 30 percent, exclusive of the heating losses, creating an inefficient engine.
Old 04-24-2011, 06:59 PM   #9
I believe you, I just remember reading years ago that they were very efficient at turning heat energy into mechanical... obviously I mis-read or mistook whatever the point was. I can see how burning wood or coal to heat water, only to be jetisoned as hot steam would be an inefficient conversion of energy.
Steam Valve Old Steam Radiators rose12346111 HVAC 1 11-29-2010 05:27 AM
Seals on steam shower doors hacksepe Building & Construction 1 04-22-2010 06:13 PM
Steam to Hydro Air Conversion RBR HVAC 1 09-17-2009 05:23 PM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 09:26 PM
Converting Steam Radiators To Hot Water johnpar HVAC 4 07-30-2008 04:34 PM
