-   Green Home Improvement (http://www.diychatroom.com/f97/)
-   -   Solutions for being "off grid" (http://www.diychatroom.com/f97/solutions-being-off-grid-52486/)
Red Squirrel 09-07-2009 03:31 PM
I've been looking at "off grid" or "partially off grid" solutions just for kicks, not that I can afford it. The two main ones seem to be solar power and wind. Solar would not work where I live as we hardly get any sun, but wind could work.
The issue with wind turbines is the space they take, the possible noise they might make, and the "standing out" factor. Also in a small yard I could see an installation being a bylaw violation. I'm guessing a small one the size of a roof vent turbine would hardly produce enough power for a single computer, let alone the whole house, so that's probably not even worth setting up, as small roof turbines came to mind.
What are other solutions that I may be overlooking? Perhaps something that can even be inside the house?
I had this crazy idea of setting up a tesla turbine at the water main, but that sounds too scary if it breaks and it would not really run long enough to produce a significant amount of power.
As for solar, it's almost an option as we do get a day here and there of extended sun and we do get more sun in winter then summer, but how well do they work in winter? I'd be concerned that they may crack from the cold, or even just get covered with snow. While expensive, it could be cool to setup an array on the roof and just keep adding a bit at a time. I have a crawlspace under my garage that is too dirty/rough to use for anything so I could put the battery bank and inverter there.
user1007 09-26-2009 09:16 AM
Recently read about these two emerging options. One is for solar tiles that blend with clay tiles and the other is for a roof ridge turbine.
http://www.srsenergy.com
http://www.thepowercollective.com
There seem to be some rumblings about whole house storage batteries that do not have the heat issues but I cannot remember where I read about them and at what stage of development they were.
mboxwell 10-07-2009 06:12 PM
Both wind and solar have their disadvantages and their advantages. Quite often it is a combination of the two that can have the best benefit.
Small wind turbines can be quite inefficient however, and getting the best out of them depends on your site.
Incidentally, I've just looked up the solar irradiance figures for Toronto and actually, they aren't as bad as you may think. They're certainly good enough to make a solar/wind combination a possible solution - assuming your site is suitable for both solar and for wind power.
Solar actually works better at colder temperatures than warmer - in fact the hotter the panels get the more inefficient they get, so during the winter your system could work quite nicely. Looking at the insolation figures, an 800w system would generate around 1kW of electricity per day during January (on average) whilst in the height of summer you could be generating around 5kW of electricity from the same system. Connected into a grid fallback system, that could be a very useful amount of power.
spark plug 10-07-2009 08:13 PM
Red Squirrel (Poster#1) As long as we're dreaming, I have my own set of wishful thinking. Maybe One day??? Namely. To harness the power of lightning! Imagine having a series of Lightning Rods capture the lightning bolts and put into huge Storage Batteries. We probably could power entire cities for months with one (renewable) charge! Eliminate confusion:yes::no: Through Education!!!:smartass: don't Drink and Drive, Ever!!!
Scuba_Dave 10-07-2009 08:15 PM
I'd build a waste oil heater
Plus convert my house to burn veggie or bio-diesel
I'm already building a solar heater, plan on more
Red Squirrel 10-11-2009 10:45 PM
I've thought of this too, but really not sure what kind of system would be able to handle that much power, and convert/store it in a matter for actual use. Guessing tons of large capacitors and some kind of regulating device that slowly drains them to charge the batteries. That would definably be awesome. I'm sure there's lot of energy in the air even without lightning. Perhaps very small lightning discharges that we don't see.
jogr 10-21-2009 03:36 PM
A simple description of lightning is that it occurs when the charge differential between two areas of atmosphere (air to air lightning) or between the atmosphere and ground (air to ground lightning or vice versa) becomes large enough to overcome the resistance of the air to the electron flow. Boom, the electrons stream over all at once.
But there is no need to wait for the lightning strike to actually occur and then hope to catch it. Instead one could draw power by setting up electrodes throughout the atmosphere and ground surface to pick up charge differences that are occuring and allow the electrons to flow in a controled manner before lightning can even occur. This would also protect anything in the area from lightning strikes because the energy is pulled off before a strike can occur.
The only real problem is the cost and that some people might not like towers and wires strung out throughout the sky.
Yoyizit 10-21-2009 05:15 PM
A nearby stream can power a turbine.
mboxwell 11-29-2009 04:25 AM
I have to say I like the idea of using a stream to generate electricity - its a constant form of power generation, which sounds great to me.
The problem is you need an awful big stream with a decent drop to get any real power. I've got a tiny little stream and I've been messing about with it - creating a dam, all that sort of stuff, but so far I've not been able to generate anything worthwhile.
I've got some silly ideas about doing something with a bicycle hub dynamo to charge up a 6v battery and using the power to run some shed lighting or something basic like that, but right now I can't see what else I can do with it...
pyper 11-29-2009 08:11 AM
My "off grid" heating solution is burning wood. The hearth is finally done, and the stove installation is set for Friday!:thumbup:
I saw a feature on TV a month or so ago about a new process for making PV panels. They use what's basically a big inkjet printer to print the panels. Cool stuff. If it works out it should bring the prices way down, and then you can just use more panels in areas where there isn't as much sun.
Most households use most of their energy to heat water for showers and laundry.
If by "off grid" you just mean literally not connected to the electric grid, then you can heat water and space with propane. It ends up costing about the same as electricity, but it's nice to have heat and hot water when the power is out.
justgreenhomes 12-04-2009 08:06 PM
I'm with Scuba_Dave on the soalr air heater and pyper, except I'd go with a pellet stove. As for PV or wind, first you need to get your load as low as you can. For every $3 you invest in conservation you can expect to save $5 in a PV system.
Yoyizit 12-04-2009 08:17 PM
Assuming 100% efficiency, 1 Therm of energy can be had from 14,000 gal/min of water falling 10' for one hour.
justgreenhomes 12-04-2009 08:55 PM
Yoyizit: you have a wealth of technical knowledge. Thanks for sharing!
Yoyizit 12-04-2009 09:33 PM
So how come I ain't rich?:(
Red Squirrel 12-04-2009 10:32 PM
That's good to know, I've always wondered if I can find a way to turn rain into electricity. In summer it rains non stop here, but certainly not 15k gal /minute! LOL
I was doing research for kicks to see how much power can be generated by a human pedling a bike attached to a generator, and it's way less then I figured. Never really realized how much it takes to get a usable amount of electricity.
