Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Green Home Improvement
Old 01-19-2012, 08:19 PM   #1
solar thermal roof with pex tubing
I would like to maybe install this type of system on a cabin I am building, and would like input from any roofing pro with knowledge of this system.
My question is: will it work (effectively provide space heat and hot water) on a house on the prairies in the middle of Saskatchewan, Canada on the coldest winter day?
Here is a link to what I am talking about.http://www.youtube.com/watch?v=d6Wek...7&feature=plcp
wwsteel7 is offline   Reply With Quote
Old 01-20-2012, 09:06 AM   #2
Exterior Construction
Windows on Wash's Avatar
Which system are you referring to?
The poly tubing under the standing seam?
Old 01-20-2012, 09:48 PM   #3
yes, the pex tubing held in place by the metal purlins, making direct contact with the underside f the standing seam metal roof.
Old 01-20-2012, 11:31 PM   #4
You will need to check the efficiency on those systems. I think you will find that they will not yield the same amount of heat the the evacuated tube systems do.
Old 01-21-2012, 08:19 AM   #5
Shut in w/o Home
seeyou's Avatar
I like the looks of that system, but I bet it costs an arm and two legs. I'd also wait until the 2nd generation until they get some of the bugs that will arise worked out.
seeyou is offline   Reply With Quote
Old 01-21-2012, 10:37 AM   #6
+1
I would bet it isn't cheap.
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
Are you ready for SNOW & ICE ? Roofmaster417 Roofing/Siding 15 10-09-2011 10:25 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 07:11 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
