Solar Storage Battery And Inverter - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 10-16-2012, 05:36 PM   #1
Solar storage battery and inverter
Where should batteries and inverter be mounted (indoors or outside)? I read that while batteries are charging they emit a flammable gas. I also read the inverter may create a spark. This sounds like a dangerous combination. How far away should the inverter be mounted from the batteries to avoid igniting the gas? Should one or both items be mounted outdoors?
Also, what is the relationship of batteries to inverter? If I have 1 12V battery, does that mean I need a 12V to 120V inverter? If I have 4 batteries, does that mean I need a 48V to 120V inverter?
john monge is offline   Reply With Quote
Old 10-16-2012, 09:18 PM   #2
Rewards Points: 125
A couple of questions here.
The inverter can be anywhere as long as you don't put them in a place too close to batteries to avoid corrosion. The batteries need a ventilated space, which is why
I put mine in a separate room with ventilation under the building. You may also want the inverter in a handier place to operate than the batteries.
The exact inverter spec depends on a few different factors; how far from batteries to inverter, what othe (DC) equipment are you running. Given the same amp hours for a given set of batteries, the way you wire them trades amps for volts, but the total watts stay more or less the same (ohms law).
So, four batteries (12v) can be wired for 12, 24, or 48 volts. If each battery is 200 amp hours, than you can get 12 v @800 amp hours for 9600 watt hours, 24 v @400 amp hours for 9600 watt hours, or 48 v @200 amp hours for - you guessed it - 9600 watt hours. BTW, you only want to rely on 50% to 60% of that total capacity. Draining batteries completely kills them in no time.
ptarmigan61 is offline   Reply With Quote
The Following User Says Thank You to ptarmigan61 For This Useful Post:
john monge (10-19-2012)
Old 10-19-2012, 06:29 PM   #3
Sorry for taking so long to respond. I just figured out how to say thanks. Your info was very helpful.
Thanx,
-john-
Old 10-19-2012, 06:29 PM   #4
"Thanx".
Old 10-19-2012, 08:20 PM   #5
Rewards Points: 125
Just glad it helped. Kind of surprised more people didn't weig in.
Old 09-19-2013, 11:02 AM   #6
Rewards Points: 1,016
If sealed batteries, such as AGM, the inverter can typically be with the batteries. If wet batteries, which emit flammable gasses then the inverter is typically separated or the area must be well ventilated. The inverter install instructions typically will speak to the requirements.
The DC input voltage of the inverter is matched to the voltage of the battery bank, regardless of how many batteries make up the battery bank.
RV Example: I have four 6 volt wet batteries wired series/parallel for a 12 volt battery bank, and a 2300w inverter located in a separate compartment.
____________
Vince
Tags
battery , inverter , solar
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 06:40 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Solar installation plan DIYGST Electrical 1 02-21-2009 06:20 PM
wire size for solar generator? krisman Electrical 12 01-28-2009 11:34 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 06:34 PM
