Solar Panels And Snow - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 12-28-2014, 11:21 AM   #1
Rewards Points: 22
Solar Panels and snow
Has anyone found a fairly easy way to get snow off panels?
Broom, salt tablets or a heat source. 2-4 in of snow melts slow on it own
Thanks for your time
Aardl
aardl is offline   Reply With Quote
Old 12-28-2014, 11:29 AM   #2
Handy44's Avatar
Rewards Points: 14
A soft broom?
Handy44 is offline   Reply With Quote
Old 12-28-2014, 02:03 PM   #3
Oso954's Avatar
Rewards Points: 1,008
I like a car or RV wash brush with an adjustable handle. They have nice soft bristles, and are made to stand up to moisture.
Being able to extend the handle helps for a longer reach.
You can use the same brush with water in the summer for cleaning dust/dirt/bird droppings off the panels.
Oso954 is online now   Reply With Quote
Old 01-05-2015, 09:43 AM   #4
Rewards Points: 202
A broom with soft bristles should do. I usually use a rake or a dust pan to trim down the snow build up until its thin enough to be brushed away. be very careful when trimming though, you wouldn't want to damage the panels. How big is your solar power system by the way?
PD_Lape is offline   Reply With Quote
Old 01-05-2015, 11:10 AM   #5
Rewards Points: 29
Plastic roof rake from Blowes. And tape a piece of pipe insulation on there if you're worried about scratching.
Ben25 is offline   Reply With Quote
Old 01-05-2015, 11:25 AM   #6
Rewards Points: 268
I typically just use a soft-bristle push broom with an extension handle. Though in my neck of the woods my panels are darn near vertical this time of year (sun very low in the sky) so I rarely need it.
Marqed97 is offline   Reply With Quote
Old 01-09-2015, 10:27 AM   #7
Rewards Points: 399
Here is my twist.....bolt three snow brooms together....remove the snow twice as fast.
DanS26 is offline   Reply With Quote
The Following User Says Thank You to DanS26 For This Useful Post:
Ben25 (01-09-2015)
Old 01-09-2015, 04:09 PM   #8
Rewards Points: 399
Ben, I'm going to try your idea. The snow brooms catch on the protruding bolts and get ragged. Putting the pipe insulation split in half on the bottom of the brooms may make for a better slip over the bolts.
Long winter ahead, so I'll see if it protects the brooms after much use.
corrugated roof panels coupe Building & Construction 4 11-25-2011 10:37 PM
RTD plywood Clutchcargo Building & Construction 16 11-24-2011 03:40 PM
How much snow can my shed roof support? Critter68 Building & Construction 6 10-15-2008 09:53 PM
Adding a snow supporting arbor snmhanson Building & Construction 2 12-15-2006 06:21 PM
