Solar Element - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 02-21-2014, 01:00 AM   #1
Solar element
I don't want reinvent the wheel so I'll ask if anyone has come an element that directly replaces an electric element with an solar coil? It seem like a simple way to supplement a hot water system.
kingfrog219 is offline   Reply With Quote
Old 02-21-2014, 05:13 AM   #2
Rewards Points: 13,994
Just Google "solar water heater".
Not cheap but it is possible to use the sun to heat the water.
Adding your location to your location to your profile is always a big help.
The closer to the equator you are the more since solar can make.
kingfrog219 (02-21-2014)
Old 02-21-2014, 09:49 AM   #3
Just the element
Hello Joe, I'm in GA and I was looking at the electric element and it looks like a 1/4" tube. I was hoping someone made an element with plumbing fitting so I could easily connect it to my collector.
Old 02-24-2014, 11:15 AM   #4
Oso954's Avatar
Rewards Points: 1,320
The coils for solar hot water tanks are too large to go in thru the element opening.
You need a lot more surface area because the temperature of the circulating water or coolant is a lot lower than the temp of the electric element.
Oso954 is offline   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Windows on Wash (02-24-2014)
Old 02-24-2014, 04:49 PM   #5
Would the increased time that the solar runs not make up for the lower temp one would get from an electric element? I was also thinking of using something besides water in the coil if I can find something non-toxic.
Old 02-26-2014, 12:10 PM   #6
Oso954's Avatar
Here is a cutaway view of a commercial solar hot water tank. Compare the size of the water coil to that of the backup electric element. If you are not thinking big coil, your heat transfer is going to be minimal.
Old 02-26-2014, 01:11 PM   #7
Thank you, that helps a lot.
Brainstorming a passive/active solar heating project, want opinions, please! YerDugliness Green Home Improvement 4 07-13-2013 06:29 PM
oven element not glowing all the way around diysNovice Appliances 10 01-20-2013 07:55 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Brand or OEM element in a water heater? spentonbargains Plumbing 4 10-06-2009 05:01 AM
