So,
I'm working on building a solar "air" heater for my work shop. It's something I've looked into for a few years, and finally decided to quit procrastinating on & get assembled this winter in my slow time. As far as design, dimensions, and function, I think that I have that pretty well covered. Afterall, I've had plenty of time to plan this out in my head.
To give some details of what I'm doing, I'll explain a little bit. I'm building two "boxes" approx. 6' wide by 12' tall each, to go into an existing 12' by 12' OH door I currently have on the South wall of the shop. I don't use this door much in winter, but it will be hinged for the few times that I will need to use it. As well, in summer I plan to simply open the solar "doors" for the season so that I'm not allowing any additional heat into the shop. The building walls are constructed of 8" CMU (concrete block), and are also furred out about 2.5" on the outside, so I have a fairly deep opening for these "doors" to fit into.
The depth is where I have a few question:
- My plan is to cover the inside of the box in corrugated aluminum coil stock, leaving the screws somewhat loose to allow for expansion. Is there a better product/material/method?
- I'll be left with an 8" cavity inside of the box. I really don't care for the whole "glued together beer can" method. I've thought about using either thin gauge steel studs, or possibly even some aluminum coil stock "tri-angles" vertically in the cavity. Is there a better way?
- I'm still considering using two layers of black window screen inside the cavity for additional absorbtion of heat. Good idea?
Thanks in advance for any suggestions you fellow members may have.
On edit, I forgot to post a picture:
