Skylight In New Construction - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 04-15-2016, 07:06 AM   #1
Rewards Points: 44
Skylight in new construction
I know skylights are the scourge of Green Home Building but its installed and planned correctly they don't have to be as much of an energy drain. My application has an orientation SSW with some tree shading and an adjacent northern eave/gable (overhang) that will shade the mid-to-late afternoon summer gain, so my biggest concern is winter heat loss and how to mitigate this. I was thinking of somehow installing a small water bladder adjacent to the skylight well but then thought I will be getting the heat into the room anyway and I would really need to mitigate the winter night time heat loss. A sliding baffle adjacent with an inch or two of poly insulation are my thoughts since the Skylight is 18 inches wide and I can almost fit this into the adjacent rafter space. Has anyone done this? Automation would be nice with a linear servo.
kurtp2 is online now   Reply With Quote
Old 04-15-2016, 01:47 PM   #2
Rewards Points: 2,630
Re: Skylight in new construction
Just make sure you but a quality skylight with high R value. And a moving shade.
I have 2 skylights on the south side. I also have electric venetian shades on them. I close the shades in May, and open them in late September. In the winter, I really like the extra light provided by the skylights. Being on the South side, the heat gain is significant on sunny days. In the summer, everything is bright, and the extra light is not necessary (and certainly the heat gain is not welcome)
If your plan is to put insulation barriers over the skylights at night in winter months, I can see that going on for a week before you tire of it and just leave them the way they are.
In the summer, the tree you mentioned will certainly help, but I would not be positive it will be the full answer. Invest in some shades too.
SPS-1 is offline   Reply With Quote
Old 04-15-2016, 08:54 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
+1
You aren't loosing that much heat through that 8 sq/ft of insulated glass.
Depending on the layout, the skylight shaft will be a bigger conduit for energy and this is peanuts as compared to your homes greater pathways of energy loss.
Old 05-10-2016, 03:16 PM   #4
Rewards Points: 722
I know you aren't really asking, but I absolutely HATE our skylight. It's East facing, with no trees to shade it. In the Winter the added light and bit of heat it seems to provide are nice, but during the summer it heats up so much it's hard to cool the room. It's in a bathroom on our 2nd floor that I plan to renovate at some point in near future and it'll likely go away by then. For now I've just taken to installing a thick drape in the space and I tend to leave it up year around as it isn't worth the hassle and I actually think I keep heat in by leaving it covered vs. the solar heat I'd get from uncovering it.
I have no clue of the R-value of the glass as it was installed prior to our purchasing of the house, but guess it was installed in the 80's-90's.
I liked it at first.....
Master Brian is offline   Reply With Quote
Old 05-10-2016, 03:23 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 812
I love skylights...but they have to be planned properly.
Mine is double pained...low E...tempered glass (California requirement).
It is also openable....located in the master bath facing north. In the summer it stays open 24-7....lets all the warm air out. In the winter, it's a great source of free light.
ddawg16 is online now   Reply With Quote
Old 11-17-2016, 01:17 AM   #6
Rewards Points: 8
Thanks for the post, Very informative.
kwick is offline   Reply With Quote
Old 11-17-2016, 04:35 AM   #7
Rewards Points: 396
I'm not sure what the roofer did with my wife's skylight. Maybe sold it to another unsuspecting soul, maybe sent it to the landfill, but I wouldn't recommend one of those things to my worst enemy.
Old 11-17-2016, 11:10 AM   #8
Rewards Points: 358
A little late to the party here but I won't install a skylight due to the tendency for them to leak and the noise created when it rains, or especially hails.
I actually have two of them right now on my porch and I'm trying to figure out how to fix the wood ceiling if I take them out when I put on a new roof.
stick\shift is offline   Reply With Quote
Old 11-17-2016, 03:14 PM   #9
Oso954's Avatar
Rewards Points: 420
If you are wanting to add natural light, I prefer the solar tubes over skylights.
Oso954 is online now   Reply With Quote
Old 11-18-2016, 06:15 AM   #10
Rewards Points: 772
Another option for summer and winter are cellular shades.. they don't have to be inside the glass.. you can buy then separately.. they just sell a regular shade with tracks to hold it up to the skylight. Pretty easy to do yourself..
You get the slight benefit of insulating properties of the cellular blind and if you want can decide to either get black out or light filtering so you get the benefit of the extra light but don't get all that extra heat... before the blinds in the summer the skylights were miserable.. but with the blinds all is good..
We put them up on 2 of our 6 skylights.. would never consider removing them..
ryansdiydad is offline   Reply With Quote
Insulating a skylight cybishop Windows and Doors 6 01-05-2013 12:59 PM
Bath exhaust fan in skylight? Daler HVAC 3 11-23-2012 07:31 PM
Curb-mount for skylight: 2 replace or not 2 replace? 5tudent Roofing/Siding 8 10-22-2012 09:27 PM
Insulating Cathedral Ceiling (area around skylight to be replaced) dcase84 Insulation 5 10-13-2012 08:31 AM
