Recycling Washing Machine Water Into Grey Water - Green Home Improvement - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Home Improvement > Green Home Improvement
Old 08-01-2009, 02:20 PM   #1
Recycling washing machine water into grey water
I've read that a great way to conserve water for use on your lawn is by
using the gray water from the washing machine. How is this conversion done? Can it be done in our home or does it have to be done when building? Ours is brick.
williamsl is offline   Reply With Quote
Old 08-03-2009, 01:21 PM   #2
Here is a link to a guide for using gray water in California as irrigation.
You will need to check your local regulations regarding the use of gray water as it may be illegal in your area to use it or it may have different treatment requirements prior to use. Possible sources of regulation would be local ordinances, the local plumbing code, and the state environmental department (or possibly county).
Also, spray irrigation is usually not allowed, only flood and drip type.
Good luck.
ChemE is offline   Reply With Quote
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Cold water hose - washing machine cmcgowan Plumbing 1 01-08-2009 10:13 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 08:36 PM
