Go Back   DIY Chatroom - DIY Home Improvement Forum > Community > Green Home Improvement
Old 10-03-2011, 05:21 AM   #1
amyevans's Avatar
A rated windows
I've been looking into these recently http://www.stormclad.co.uk/arated.php
Does anyone know anymore about this type of window?
Apparently they reduce the energy lost through the windows to zero; is this even possible? And does anyone know how much this might save on heating bills?
amyevans is offline   Reply With Quote
Old 10-03-2011, 05:56 AM   #2
A rated windows
They State zero none but there graph shows A has 1.2 rating. For zero loss I think the rating would have to be 0. Even a vacuum thermos bottle has heat loss. My opinion not possible to have zero heat loss if the outside temperature is lower than inside temperature. Maybe contact them for clarification of the zero none statement
ralphf is offline   Reply With Quote
Old 10-03-2011, 11:48 AM   #3
amyevans's Avatar
A rated windows
Thanks Ralph, that's what I was thinking, except you've actually managed to explain why I was thinking it!
I just might give them a call...
Old 10-03-2011, 02:43 PM   #4
Architectural Designer
AGWhitehouse's Avatar
A rated windows
Well that's false advertisement if I've every seen it. It says an "A" rating is the highest a double pane window can achieve. I can tell you that a double-pane window is not the most efficient window available. When you call them, ask what the U-value is. U-value is the inverse of the R-value (thermal resistance value).
The industry "Energy Star" efficiency windows right now are R-5 (U-0.20). These are triple pane. There are more efficient windows but they can get really pricey and sometimes totally custom.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 10-05-2011, 07:38 PM   #5
A rated windows
Now the OP is really going to be confused. His location is England. U value in Europe is measured in Watts......., and in the US they are measured in BTU........ (too many units to list them all).
So they are different. I read where European U value is 5.678 times bigger than US U value. If this is accurate than a US 0.2 equals a European 1.14 U value. These guys were advertising 1.2. So That would make these rather good windows, but not extraordinary windows.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
AGWhitehouse (10-06-2011)
Old 10-06-2011, 10:53 AM   #6
A rated windows
Oooohhh...Thanks! Maybe someday, as technology brings us closer together, we'll have common systems and measurements.
Old 11-16-2011, 01:09 PM   #7
A rated windows
I don't think I'll get used to telling people I weigh about 11 1/2 stone.
operagost is offline   Reply With Quote
Old 11-16-2011, 03:05 PM   #8
the Musigician
DangerMouse's Avatar
A rated windows
Thank you for the laugh....
BTU stands for WHAT again?
Yeah, it's confusing all right. Maybe someday we'll all speak the same language too.....?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Andersen vs Jeld Wend Replacement Windows ... JasonCA Remodeling 13 03-20-2012 11:46 PM
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
